It is currently Sat Oct 24, 2026 3:28 am
Post Posted: Wed Feb 27, 2013 8:34 am
Could I please get the measurement of NT and WT spring spacing.
Front and rear.
Couldnt find any definitive measurement in a search. Would be handy to have this info readily availavle.
Thanks.
Post Posted: Wed Feb 27, 2013 8:40 am
Didn't Bog Frog do a write up either on here or outers
Post Posted: Wed Feb 27, 2013 8:52 am
Yeah. No measurement though.
Post Posted: Wed Feb 27, 2013 9:16 am
WT front: 720mm
WT rear: 950mm
CONFIRMED ACCURATE
Post Posted: Wed Feb 27, 2013 9:25 am
NT front: 640mm
NT rear: 870mm
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Feb 27, 2013 9:44 am
Ill measure mine tonight (nt)
Post Posted: Wed Feb 27, 2013 9:53 am
I thought the chassis were the same bar the hanger spacing? If so whip out ya tape and measure the separation of the inner rail right at the rear and front and add the width of a rail to this since the hangers on an NT are centered on the rails. This will give you the spacing measurements for NT.
Post Posted: Wed Feb 27, 2013 10:19 am
The front is JR, but the back isn't quite exactly under the rails from memory
Steve
Post Posted: Wed Feb 27, 2013 10:37 am
If anything are they spaced wider, towards the outside of the rail? I'm sure that Dan is chasing a flexxy setup so provided the springs clear the diff center wouldn't it be beneficial and simpler to position them dead center of the rails, even inboard them slightly more?
Post Posted: Wed Feb 27, 2013 10:39 am
I just checked, The rear hanger on the rear springs is directly underneath, the front mount of the rear springs is next to the chassis rail.
Post Posted: Wed Feb 27, 2013 11:56 am
I actually just wanted WT to mount my perches on the floater at work but thought this could become a decent tech thread with all measurements
Post Posted: Wed Feb 27, 2013 12:27 pm
Perch measurements- center to center.
NT Front: 640mm
NT Rear: 880mm
WT Front: 730mm
WT Rear: 960mm
That's what I got anyway, not sure if I held my tounge right when measuring though! :lol:
Post Posted: Wed Feb 27, 2013 2:33 pm
On the useful tec subject, I do find the vit and sammy bibles with links, on sites that wont be named Very handy (but not complete).... hint.... hint...
I dunno if your allowed to mention that kinda stuff or if I talked about a taboo item - but anyway.........
Post Posted: Sat Mar 02, 2013 8:35 am
Hope you guys don't mind me linking over to my forum but I'm on my phone so can't link the pictures across.
Here's a thread with a few chassis diagrams from the factory service manuals etc.
The spring spacings are shown on each diagram.
http://www.suzukiclubuk.co.uk/forum1/vi ... 78/#p17678
Post Posted: Sat Mar 02, 2013 9:43 am
viewforum.php?f=17
Vehicle: Lwb Sierra
Post Posted: Mon Mar 16, 2015 5:53 am
NT rear is 840
Post Posted: Mon Mar 16, 2015 10:00 pm
DAZOOK wrote:
NT rear is 840
Not according to the factory chassis diagrams, these are taken from the diagrams in the link I posted above but can also be found here http://www.suzukiclubuk.co.uk/tech-spec ... s-diagrams
NT Front: 640mm
NT Rear: 870mm
WT Front: 720mm
WT Rear: 950mm
Vehicle: Suzuki SJ70 & SJ51T
Post Posted: Sun Apr 05, 2015 7:22 pm
Is it possable to run twin perches on a diff to make it easy to swap in between cars
Vehicle: sj51
Post Posted: Sun Apr 05, 2015 7:34 pm
nope..
I'm back..... Again
Post Posted: Sun Apr 05, 2015 7:37 pm
With careful consideration, and some custom fab I think you could find a way.
Post Posted: Sun Apr 05, 2015 7:41 pm
Just a weird desire...
Vehicle: sj51
Post Posted: Sun Apr 05, 2015 7:44 pm
one big perch with sleved holes though it would work... but why?
I'm back..... Again
Post Posted: Sun Apr 05, 2015 9:47 pm
Considering swapping means dicking around with brakes and brake fluid etc
buying an extra WT diffs (a set for both) would be easily justified.
If trying to use upgraded/modified and/or locked diffs between a DD and a trail rig, I could understand the desire.
But in practice itd be a PITA
Post Posted: Mon Apr 06, 2015 8:10 am
It is possible but probably quite hard to do with stock axles, my axles are sleeved with 3" tube so it's easy to have a decent length perch that can be used for both.
I haven't got any pics of the front but it's pretty much the same. Only reason mine are like this is because they were originally built for WT spacing and it was the easiest way to modify them to fit my NT Sj, however they might be going back under a WT Lwb soon so it's pretty handy.
Users browsing this forum: Google [Bot] and 125 guests
