It is currently Thu Nov 05, 2026 3:04 am
Post Posted: Tue Feb 26, 2013 1:03 pm
tony any chance of another pic of the front of the motor. but more front on?
Post Posted: Tue Feb 26, 2013 1:32 pm
Like This -
Post Posted: Tue Feb 26, 2013 1:39 pm
yep thats it perfect.
Post Posted: Tue Feb 26, 2013 1:49 pm
Well - do tell
Post Posted: Tue Feb 26, 2013 1:57 pm
sussing out power steering pump position while im at "work"
looks like i might be able to drop the original alternator position down.
and put a small pump above it.
Post Posted: Tue Feb 26, 2013 2:05 pm
Philistine - you should be beaten with the arse bone of a Jew - or is that a jawbone of an ass - I always get that bit wrong :wink:
Post Posted: Thu Feb 28, 2013 1:46 pm
IF you could get rid of the dizzy it would be very easy to mount it there :wink:
Post Posted: Thu Feb 28, 2013 1:52 pm
there is no way a powersteering pump is going to steal half of the power from it.
yes it will sap a little bit but it will be worth it to be able to turn the wheels.
JR, get to work on the efi for me then :D
Post Posted: Thu Mar 07, 2013 8:29 am
i sat and figured out how im gonna fit the power steering pump last night.
a second crank pulley will slide on to the crank directly infront of the original, it replaces the boss that the fan fits too. ( i run a thermo)
and NH pajero pump will swing in on a bracket under the engine.
Post Posted: Thu Mar 07, 2013 10:48 am
So how far away will it be from the first belt?
Post Posted: Thu Mar 07, 2013 10:52 am
the two belts will be around 30-40mm apart i would say
Post Posted: Fri Mar 15, 2013 11:03 am
picked up a cheep jimny powersteering box.
all braketry has now been removed from the chassis and old steering arms tossed across the shed floor.
just need to drill holes, add crush tubes and bracing plates.
come up with some steering arms
change out the LJ steering column for a sierra one.
plumb in the pajero pump
bask in the glory that is actually being able to turn the steering.
Post Posted: Sat Mar 16, 2013 6:10 am
So what happens when the engine starts backwards to the PS... just wondering. Interested to see it in action, a few too many Jimny bits IMO haha.
Post Posted: Sat Mar 16, 2013 6:13 am
Hmmm. Hadnt considered the running backwards thing. But thats only happened to me once ever
Post Posted: Sat Mar 16, 2013 6:35 am
May just loose some fluid? You'll shut it down pretty quick anywho. :lol:
Post Posted: Sat Mar 16, 2013 11:17 am
hillbilly wrote:
maybe my idea of the string through the front wheels(billy cart)wasnt such a bad idea...
You're too rough hillbilly, at least use telstra rope.
Post Posted: Sun Mar 17, 2013 5:09 am
I think the worst that will happen is the non pressure line gets pressurised and blows a hose
Post Posted: Sun Mar 17, 2013 5:28 am
Can't say I've ever had much to do with power steer but I thought it might only try to pressurize the reservoir? Anyway it will only run backwards if the timing is 'tarded. When you run an engine that only had 33 hp 28 years ago you tend to stay on top of these things.
Post Posted: Sun Mar 17, 2013 11:43 am
We use steering pumps with a large reserve tank as bucket brakes on our self tipping hoists - If you only use a small tank the oil gets pushed out when the pump runs backwards,
Post Posted: Mon Mar 18, 2013 6:56 am
Thanks tony. Great tech
Post Posted: Mon Mar 18, 2013 10:32 am
Ran into some issues with the steering arms jamming over the weekend. i had to move my diff back 25mm.
pump is all fitted up to the pump. Im waiting on a 650mm vbelt to come through in the mail.
sierra steering colomn shroud was modded and bolted up to the fire wall to support the stock inner shaft.
fully intended on taking lots of pics and documenting what we did, but ran out of time. i'll try and take pics before we put the engine back in place.
Post Posted: Mon Mar 25, 2013 9:02 am
Grabbed a magna power steering hose and 121 resivour.
Its working perfectly. just need some o rings to fix a minor leak.
Top down view of the front pully and pump
from the bottom up of the pump
jimny power steer box and steering arms
steering arms, and also my custom front diff
Users browsing this forum: Google [Bot] and 318 guests
