It is currently Thu Nov 05, 2026 3:05 am
Vehicle: Getting parts atm
Post Posted: Fri Mar 29, 2013 8:26 am
What's the triks to line up splines when bolting up an uto to a g16b?
Parry
Post Posted: Fri Mar 29, 2013 8:27 am
turn and shit
Post Posted: Fri Mar 29, 2013 8:38 am
Yeah been doing that, just doesn't seem to wanna go together
Post Posted: Fri Mar 29, 2013 8:47 am
put the convertor in the auto and get it all the way in by hand
then bolt it to the box and bolt the convertor to the flex plate
if you bolt the convertor to the flex plate and then try and seat it into the box while offering it up to the engine you will damage things, its been done here several times already
Post Posted: Fri Mar 29, 2013 10:20 am
Thanks Royce, I did a search but couldn't find what I was looking for, it's all bolted up now,
Post Posted: Fri Mar 29, 2013 3:26 pm
I dont reckon you would of found it as the threads were along the lines of just put a new engine in and my gearbox is making bad noises, or its spewing oil out everywhere or it all just went bang :)
Post Posted: Fri Mar 29, 2013 11:07 pm
X2. Convertor ALWAYS gous onto the input spline of the auto first.
Post Posted: Sat Mar 30, 2013 1:21 pm
Is that also for when you have the box still in the car and put the engine in?
Post Posted: Sat Mar 30, 2013 1:57 pm
yep, always put the convertor into the auto first, its why its so easy to bolt it to the flex plate after the engine is bolted in
plus if you leave the convertor in when you pull them apart, you dont get a whole heap of oil everywhere
Post Posted: Sat Mar 30, 2013 2:06 pm
From?
Post Posted: Sat Mar 30, 2013 2:21 pm
When you pull the converter off the input it pours oil out
Post Posted: Sat Mar 30, 2013 2:27 pm
Thats bad - Mine didn't :?
Post Posted: Sat Mar 30, 2013 3:21 pm
Always leave the converter on the input shaft. Undo the bolts from the flex plate when removing the motor.
Users browsing this forum: Google [Bot] and 278 guests
