It is currently Fri Nov 06, 2026 1:30 pm
Post Posted: Tue Apr 09, 2013 9:35 am
I have the updated interior in my 03 gv. The spot where the foglight switch and the weird waste of space next to it to the right of the steering wheel ,is where i want to put some rocker swithces. I have just pulled out the section and with some grinding and shaping i can only fit one.
Doe's anyone know the sizes of the ARB panels? Ideally I would like to have 4, I have a led light bar switch and a spotight switch, and momentary winch in out rocker.
I might have to get a piece of plain black plastic and glue it in position and cut out the holes?
Post Posted: Tue Apr 09, 2013 9:37 am
Holes are 36mm by 22mm.
http://www.ebay.com.au/itm/Rocker-switc ... 550wt_1037
Post Posted: Tue Apr 09, 2013 9:54 am
Yeah i know the hole size, i'm after a panel sizes that hold multiple switches.
Post Posted: Tue Apr 09, 2013 10:01 am
Hmmm just searching, seems most are 3 wide. For front locker, rear locker and compressor.
Post Posted: Tue Apr 09, 2013 10:09 am
You can get them in pairs, possibly just go 2 lots one above the other (after you've made your filler panel)? Reckon you are going to have to butcher the dash a fair bit to get 4 in there still though.
The earlier dash design has a stupid layout there also, a whole heap of switch blanks which are too small/deep to be used for anything. Might have to do something similar to what you are doing.
Post Posted: Tue Apr 09, 2013 10:17 am
Another option.... use this and just put your 3 way winch switch in another spot instead?
http://www.ebay.com.au/itm/4-Gang-Alumi ... 372wt_1210
Or if you wanted to be really tricky - use the 4 switch version (http://www.ebay.com.au/itm/4-Gang-Alumi ... 372wt_1210) but replace the rocker switches in it with the ones you've already got (assuming they are the same size)?
Post Posted: Tue Apr 09, 2013 10:20 am
I really want to utilize that position. I think a trip to u-pull it is in order, go and get a bit of dash to fill it in for the cut outs.
Post Posted: Tue Apr 09, 2013 10:22 am
Armsup to chopping up cars in u-steal it
Post Posted: Wed Apr 10, 2013 8:58 am
4 gang house plate
U can get switch mechs to do anything u want
I have a 6 gang one in that spot in my vit
Post Posted: Wed Apr 10, 2013 9:45 am
What about using 4 of these chop?
http://www.customrockers.com.au/epages/ ... SECTION%22
Post Posted: Wed Apr 10, 2013 10:03 am
I looked at those, but i would still need something for them to sit in as the opening i am putting them in would be slightly bigger.
I went to u-pinch it yesterday and got a flat bit of dash plastic that will fill the hole and i'll be cutting four holes out of for the switches.
Post Posted: Wed Apr 10, 2013 11:04 am
Post up some pics when ya finshed ill most likely copy what your doing mate
Post Posted: Wed Apr 10, 2013 1:08 pm
Did they have any zooks in stock?
Post Posted: Wed Apr 10, 2013 1:39 pm
1 raped sierra and 1 raped swb early vitara.
Post Posted: Thu Apr 11, 2013 11:40 am
I ended up with some similar colour dash plastic from a wreck at u-pinch it.
And cut it slightly bigger than this hole
Then used the original insert that held the foglight switch and some useless compartment/section to the side as a template.
On the inside of the outer dash there are four locating prongs, i did all six but you only need the side four not the bottom two.
I grooved them out and cut out the switch holes with my knock off dremel.
I will fit a momentary rocker switch for the winch in-out in the bottom slot. I will also get an on/off switch for the winch mounted somewhere else on the dash.
I will also be using some double sided tape to hold it in position and make it a snug fit.
Post Posted: Thu Apr 11, 2013 12:33 pm
Do away with your indicators, as no one uses them in this state anyway...rewire winch in and out to indicator stalk,.. killa bro. Armsup
Post Posted: Thu Apr 11, 2013 1:50 pm
Nah better keep em, the broke government has been getting the establishment to fine people for not indicating on roundabouts :roll:
Post Posted: Thu Apr 11, 2013 1:55 pm
what brand are the switches?
Post Posted: Thu Apr 11, 2013 2:23 pm
Through these guys
http://www.customrockers.com.au/epages/ ... s/cucu3348
Post Posted: Thu Apr 11, 2013 2:33 pm
any measurment on how deep they sit inward?
Users browsing this forum: Google [Bot] and 21 guests
