It is currently Thu Nov 05, 2026 10:49 pm
Post Posted: Tue Apr 23, 2013 12:07 am
just need to know if this is just my car, or if every other vit is the same.
I have air con in my current lwb (1991) but when I stop, the air gets warm to a point if i'm stopped long enough, its not cold.
does the vit need to be moving for the air to be cold?
can I get the system working so I stays relatively cold when not moving much or fast?
can I get it to work like Toyota air cons?
I also noticed that there are a couple of different air con set ups in earlier vitaras. are these genuine and aftermarket?
the thermo fan is also cactus, so I spent all arvo pulling it off. should I replace it with an identical unit?
or can I replace it with a larger diameter fan?
i'd like to get the air con to work reasonably well when going slow or stationary. any help is greatly appreciated.
Post Posted: Tue Apr 23, 2013 7:10 pm
You identified your own problem
replace the fan and you ac will work fine, a more efficient fan may be desirable but i dont think it would be necessary unless you use the thermo fan in sand etc
Users browsing this forum: fordem, Google Adsense [Bot] and 117 guests
