It is currently Sat Aug 01, 2026 11:36 pm
Vehicle: 1996 Leaf Sierra - Soft Top
Post Posted: Tue Jul 02, 2013 2:23 pm
Hey,
apparently this is really easy to do, but it would be great if some of you helped me out a little here...
I need to install a new speedometer cable into my 96 Sierra. I have the cable and everything needed, its just i dont want to break anything in the process and I want to make sure I do it all right.
I have tried to take the dash off around the steering wheel though it gets stuck/ doesnt go over the hazard switch. How do I go about getting that off?
If you could help me with the process of this install that would be great!
All help, information and images is greatly appreciated
Thanks,
Thomas.
Vehicle: 4wd
Post Posted: Tue Jul 02, 2013 4:04 pm
Drop the steering column. Two T30 (I think) bolts, just a bit further down the column from the plastic surround. This will give you just enough room to pull the cluster back enough to give you just enough room to plug the cable in.
Then through the fire wall and you should be able to work it out from there (ie same as the one you took out).
BUT, before you remove the old one just check that it hadn't popped out from the back of the cluster first.
Watch out or you'll get sued.
Post Posted: Tue Jul 02, 2013 4:41 pm
Thank you very much... Didnt know you could drop it. Thanks!
Will go do that now.
Post Posted: Tue Jul 02, 2013 8:03 pm
Sierra speedo cables don't go through the firewall.
I've changed a few without removing the cluster or dropping the column.
The only thing that is sometimes difficult is the routing of the original cable above the heater box making it hard to remove.
Post Posted: Wed Jul 03, 2013 4:38 pm
Yeah thank you.
I got it all done, but it was quite a struggle trying to get it behind the heater. But its done, though I went driving with a GPS which tells me the exact speed and its reading 10km slow...
Any idea how to fix this?
Users browsing this forum: No registered users and 1263 guests
