It is currently Tue Nov 03, 2026 5:02 pm
Vehicle: Suzuki jimny, WT sierra, GTR.
Post Posted: Thu Aug 01, 2013 9:16 pm
Hey guys,
Partly rounded off my jimny gearbox drain plug last weekend trying to get the bugger off for a much needed oil change. Shifting has gotten a bit stiff over the past few weeks and I suspect there is water in it.
I'm going to have to take to it with a cold chisel so I'm going to need a replacement. Suzuki does not have any in stock within Australia and they Are on back order from overseas and could take up to a month. My jimny is my daily so I need to take care of this ASAP.
Does anyone know of where I could find a replacement aftermarket plug?
Post Posted: Thu Aug 01, 2013 10:02 pm
Take it to a Fastener place. Perhaps they have a bolt or large 'grub screw' that could suffice for the moment.
Post Posted: Thu Aug 01, 2013 10:05 pm
buy a 10mm square drain plug socket & go to a self serve wreckers & pull one out of another zook or go to a suzuki wrecking yard & buy one? :?
Vehicle: SJ80, SE416
Post Posted: Fri Aug 02, 2013 8:35 am
Suzuki shops? They usually have the stuff Suzuki Australia doesn't keep in stock...
Is the drain plug on the VVT model the same as the non-VVT one?
http://www.suzistore.com.au/onlinestore/four-wheel-drives/jimny/jimny-sn413-m13a/transmission1263922497/PLUG-DRAIN-TRANSFER---GEARBOX---DIFF-1870-detail.html
Post Posted: Fri Aug 02, 2013 8:58 am
Just go to a bolt shop they will have em for like $4.
I now need 24mm socket to take mine off... Not going to round off anytime soon :D
Post Posted: Fri Aug 02, 2013 9:34 am
^^^ I need to get some of those
Post Posted: Fri Aug 02, 2013 9:36 am
Thanks for the replies, I should have mentioned that I really did not want a second hand one but a visit to a bolt shop might be on the money.
Post Posted: Fri Aug 02, 2013 10:17 am
2nd hand one would get you out of trouble until a new one rocked up.
if you're going to get one from a bolt shop make sure it's got a magnet in it.
Users browsing this forum: Google [Bot] and 419 guests
