It is currently Tue Nov 03, 2026 10:34 pm
Vehicle: SJ51T
Post Posted: Thu Aug 08, 2013 12:36 am
I'm at the part where I want to mount the baleno ECU nicely inside the cab so who has suggestions or pics on How they got their g16b wiring through the sierra firewall?
Post Posted: Thu Aug 08, 2013 5:02 am
Check the tug build. I drilled a Baleno sized hole on the firewall and used the Baleno firewall grommet.
Post Posted: Thu Aug 08, 2013 6:08 am
I used a Vit loom and G16B in my Sierra.
Just bought a 50mm hole saw and put the hole next to the original Sierra loom hole then used the stock Vit grommet that was already on the loom.
Vehicle: SJ51T
Post Posted: Thu Aug 08, 2013 10:14 am
Hole saw an electrical tape it is then!
(Until I can find a grommet to suit as my donor has gone to car heaven.
Think I threw the baleno cluster away too
Post Posted: Thu Aug 08, 2013 11:52 am
If you Wanted the VSS thing out of it, you can buy a 'reed switch' from jaycar for around $2.
It works the same as I have used the jaycar reed switch before.
Post Posted: Thu Aug 08, 2013 11:58 am
No vss in a coil pack baleno. They use an electronic speedo.
Post Posted: Thu Aug 08, 2013 12:13 pm
Bugger :( no good then.
Post Posted: Thu Aug 08, 2013 12:57 pm
Clark rubber do universal firewall grommets or you can get one from a car at the wreckers.
Post Posted: Thu Aug 08, 2013 6:15 pm
For temporary grommets, I split a length of eg vacuum hose, and run it round the hole.
Sometimes this stays temporary a long time :)
Users browsing this forum: No registered users and 100 guests
