| Author |
Message |
jonfromhamilton
Joined: Mon Dec 26, 2011 2:11 pm Posts: 410 Location: Pakenham
Vehicle: SJ51T
 Posted: Thu Aug 08, 2013 12:36 am |
I'm at the part where I want to mount the baleno ECU nicely inside the cab so who has suggestions or pics on How they got their g16b wiring through the sierra firewall?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13016 Location: Melbourne
 Posted: Thu Aug 08, 2013 5:02 am |
Check the tug build. I drilled a Baleno sized hole on the firewall and used the Baleno firewall grommet.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu Aug 08, 2013 6:08 am |
I used a Vit loom and G16B in my Sierra. Just bought a 50mm hole saw and put the hole next to the original Sierra loom hole then used the stock Vit grommet that was already on the loom.
jonfromhamilton
Vehicle: SJ51T
 Posted: Thu Aug 08, 2013 10:14 am |
Hole saw an electrical tape it is then! (Until I can find a grommet to suit as my donor has gone to car heaven. Think I threw the baleno cluster away too
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Thu Aug 08, 2013 11:52 am |
If you Wanted the VSS thing out of it, you can buy a 'reed switch' from jaycar for around $2.
It works the same as I have used the jaycar reed switch before.
Gwagensteve
 Posted: Thu Aug 08, 2013 11:58 am |
No vss in a coil pack baleno. They use an electronic speedo.
31zook
 Posted: Thu Aug 08, 2013 12:13 pm |
Bugger  no good then.
jono165
Joined: Thu May 27, 2010 12:01 pm Posts: 834 Location: Melbourne
 Posted: Thu Aug 08, 2013 12:57 pm |
Clark rubber do universal firewall grommets or you can get one from a car at the wreckers.
christover1
 Posted: Thu Aug 08, 2013 6:15 pm |
For temporary grommets, I split a length of eg vacuum hose, and run it round the hole. Sometimes this stays temporary a long time
