Hey all I'm looking at buying this kit off bentT but I was wondering would 1 litre front discs and clippers bolt up to this kit? Only reason is I have a 1 litre ute and doing a wt convertion and will have the spare 1.0 diffs laying around. Any info will be great. Cheers
This kit is a bolt on resr disc brake conversion for the Sierra, which uses Sierra front discs and calipers on the rear axle.
Suzuki Samurai / Sierra / SJ413 front brake calipers Suzuki Samurai / Sierra / SJ413 front discs – DBA510
NOTE: This kit makes no provision for a handbrake / parking brake. Options include using a transfer mounted drum handbrake, or hydraulic line locks.
This kit also makes no provision for brake proportioning. A proportioning valve is highly recommended. Vitara LWB front discs and calipers bolt on to the front axle, and can also improve proportioning as the LWB calipers have a larger piston.
Users browsing this forum: No registered users and 175 guests
