It is currently Tue Oct 20, 2026 1:41 am
Vehicle: 84 Lwb Ute
Post Posted: Sun Sep 15, 2013 8:47 am
Hey all I'm looking at buying this kit off bentT but I was wondering would 1 litre front discs and clippers bolt up to this kit? Only reason is I have a 1 litre ute and doing a wt convertion and will have the spare 1.0 diffs laying around. Any info will be great. Cheers
This kit is a bolt on resr disc brake conversion for the Sierra, which uses Sierra front discs and calipers on the rear axle.
Kit contains:
2 caliper mounting bracket
2 disc mounting adaptors
2 brake hose brackets
10 Suzuki wheel studs
8 bracket mounting bolts
8 nyloc nuts
4 caliper mounting bolts
4 spring washers
Hose retaining clips
Instructions
Parts required:
Suzuki Samurai / Sierra / SJ413 front brake calipers
Suzuki Samurai / Sierra / SJ413 front discs – DBA510
NOTE: This kit makes no provision for a handbrake / parking brake. Options include using a transfer mounted drum handbrake, or hydraulic line locks.
This kit also makes no provision for brake proportioning. A proportioning valve is highly recommended. Vitara LWB front discs and calipers bolt on to the front axle, and can also improve proportioning as the LWB calipers have a larger piston.
Price is $240 AU + $40 AU shipping.
Post Posted: Sun Sep 15, 2013 8:51 am
Yes. 1.0 rotors and calipers are the same as 1.3 (leaf)
Users browsing this forum: Google [Bot] and 201 guests
