Hey I am trying to get a transfer mounted drum brake apart to replace the shoes. My understanding is pull the tail shaft and centre nut then drum off. I am having a prick of a time with the nut behind the flange, the nut looks like it has 2 tabs that lock it in place but no amount of effort will shift the tabs or nut. Is there a trick to this that I am missing?
The are very very tight. I had to use a pipe over the handle, and push with both feet, to get mine off. Sometimes the tabs need more lifting than expected.
Users browsing this forum: Google [Bot] and 526 guests
