It is currently Tue Nov 03, 2026 9:15 am
Vehicle: 85 Holden Drover
Post Posted: Tue Sep 24, 2013 5:21 pm
Hey
I am trying to get a transfer mounted drum brake apart to replace the shoes.
My understanding is pull the tail shaft and centre nut then drum off.
I am having a prick of a time with the nut behind the flange, the nut looks like it has 2 tabs that lock it in place but
no amount of effort will shift the tabs or nut.
Is there a trick to this that I am missing?
Vehicle: Drover pickup turk
Post Posted: Tue Sep 24, 2013 5:59 pm
The 'tabs' have been punched in, I think I used a small screwdriver to get behind them and push them out when I did my transfer.
I like the tuna here
Post Posted: Tue Sep 24, 2013 6:03 pm
The are very very tight.
I had to use a pipe over the handle, and push with both feet, to get mine off.
Sometimes the tabs need more lifting than expected.
Post Posted: Tue Sep 24, 2013 6:32 pm
Rattle gun helps even that you mite need to get a bar and pipe out
Post Posted: Tue Sep 24, 2013 6:46 pm
No worries, wasn't sure whether to just lever the hell out of the tabs or not. Will get a rattle gun on it at work tomorrow and try again.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 75 guests
