It is currently Sat Oct 17, 2026 11:56 pm
Post Posted: Fri Sep 27, 2013 10:15 am
So im looking into the ins and outs of building a buggy.
I know that hydro steering is the way to go, but im wondering if you really need to go to the extent of buying orbitals, double ended rams, blah blah blah.
Could you not, just use hydro assist lines nfrom your steering box, hooked up to a ram but use it as the only method of steering and do away with the main drag link completely
Post Posted: Fri Sep 27, 2013 3:16 pm
It won't work unless the pitman arm has a load on it.
Post Posted: Fri Sep 27, 2013 4:23 pm
ahh ok, is that how it works
Post Posted: Fri Sep 27, 2013 6:11 pm
You could use an orbital and run a single ended ram on a tie rod.
Post Posted: Sat Sep 28, 2013 6:56 am
http://www.howstuffworks.com/steering4.htm
Post Posted: Sun Sep 29, 2013 9:19 pm
Single ended rams need different rotation in each direction. I.E 3 turns to the left 5 to the right.
And to got a double ended ram is only $350 and the rest of the hydro system works the same anyway.
Post Posted: Mon Sep 30, 2013 6:08 am
Not true to that extreme josh. That was just how appsies went. Pretty sure its fixed now with his new orby.
Post Posted: Mon Sep 30, 2013 6:58 am
Unless his orbital can increase flow/pressure in one direction the car will always steer slower one way than the other.
Pressure = Force of hydraulic fluid x Area of contact
Single ended ram for example:
To the left
Pressure = Force of hydraulic fluid x Area of piston
To the right
Pressure = Force of hydraulic fluid x (Area of piston - Area of the rod)
Double ended ram has identical areas for steering left or right, allowing the speed to be the same and the rotations of the wheel.
Post Posted: Mon Sep 30, 2013 7:06 am
Yeah, they are uneven. But the 3/5 is bad. Its not that bad in other cars ive driven.
Vehicle: Getting parts atm
Post Posted: Mon Sep 30, 2013 6:02 pm
If you search around, hydro ain't all that expensive...
Post Posted: Mon Sep 30, 2013 7:59 pm
Nah, its not.
But say $200 saved in one spot can go somewhere else. I would get double ended, but tanshi may not want to for budgeting reasons.
Post Posted: Tue Oct 01, 2013 7:05 am
The good quality gear isn't really that cheap either, depends how much you want a trouble free weekend when you want to wheel in my opinion.
Post Posted: Tue Oct 01, 2013 8:04 am
how can quality really differ? is it better to get cheeper rams and a better quality orbital? obviously you want the best of both but not every one needs a $3000 PSC kit
Post Posted: Tue Oct 01, 2013 12:47 pm
Pump and lines should be priority in my opinion.
Heavy duty lines and proper crimped fittings. A blown fitting is a pain in the arse. As is a damged hose.
And no good having good hydro steer if your pump cant keep up/handle continuous stress.
Keep it cool too.
Post Posted: Tue Oct 01, 2013 7:50 pm
I'm currently waiting to get a quote back from poly performance for freight but a PSC kit even from Australian retailers will not cost $3000 unless you've got one hell of a ram on there, it's looking much less from overseas if duty can be avoided.
I agree with Dan. For me you want a good pump, great cooling and a matched orbital and ram. Look at the flow rates, decide how much you want to turn the wheel lock to lock, make an informed decision and go from there. Lines and fittings need to be up to the task, they are the last line of having any control over your steering.
Post Posted: Tue Oct 01, 2013 8:15 pm
Have been a long way into a creek and damaged a front steer line. Was very difficult to get out.
Also been stuck after a reuseable fitting blew.
Post Posted: Thu Oct 03, 2013 6:48 pm
Those fittings usually only let go for 3 reasons if everything this is otherwise good......
1. That have been reused...field attachable they are, reusable they are not meant to be...
2. Wrong fitting/hose combo
3. not fitted correctly
Since a properly set up steer system should only be running at a moderate pressure, screw on fittings should not be an issue. I would have no issue running a screw on type fitting and a 3/8 sized hose to 3500-4000 psi...steering would run at maybe 1500-1800 max psi if ram is sized correctly.
A single rod cylinder designed for steering will usually have a smallish rod, this will minimize the difference in turns L-L. Ag style cylinders are usually cheaper, but most use a larger rod and this will make the difference in L-L more noticeable. No reason you could not run 2 x smaller single rod cylinders, one on each side, either.
To be honest, I have never seen a 'cheap' orbital valve, plenty of Eaton (Char-Lynn), Danfoss and a few TRW/Ross and ZF's. They are, and really need to be, a fairly precision bit of gear.
Users browsing this forum: No registered users and 275 guests
