It is currently Sat Oct 17, 2026 2:10 am
Vehicle: Suzuki Sierra 1996 SJ80
Post Posted: Sat Oct 05, 2013 8:19 pm
Hey guys, I think some previous owner who installed a after market stereo wired the power to the tailight fuse and every time the radio is on and I turn my headlights the tail light fuse blows and the radio stops and the clock also.
Best solution?
Throw your recommendations at me please!
Thanks
Vehicle: 4wd
Post Posted: Sat Oct 05, 2013 8:55 pm
Personally I'd remove the stereo, speaker and all the wiring, however trace and remove the power from the tail light fuse and power is correctly.
Watch out or you'll get sued.
Can I hardwore stereo to battery
Vehicle: 4wd
Post Posted: Sat Oct 05, 2013 9:06 pm
Yes, but why?
The original power source for the radio has it's own fuse in the fuse box (shared with the cigarette lighter), I'd be tapping back into that.
Vehicle: 1995 Vitara, SWB
Post Posted: Sat Oct 05, 2013 9:09 pm
Sure can. You will need to add an inline fuse however.
Direct wiring from the battery will also mean that you have constant power to the stereo, which means that if you have the stereo on, turning the key off will not turn the stereo off.
Greater chance of flat battery syndrome. :( :( :(
better off to wire it into the factory wiring for the stereo which should still be there or piggy back the cig lighter supply wire. Armsup Armsup
Sorry stockman, just saw your post.
we are on the same track though. Armsup
Post Posted: Sat Oct 05, 2013 9:27 pm
with reconnecting the wires back to the original fuse, is that just a case of soldering them wires back onto it?
would the interior light run off the same fuse as the tailights?
Thanks guys, great help
Vehicle: 4wd
Post Posted: Sat Oct 05, 2013 9:32 pm
In effect yes, but check that the wire isn't still there.
Yes, interior light is on the same circuit as the brake light switch.
Vehicle: 89 Sierra Widetrack
I had the same issue once when I installed my first radio.
I connected the power to the original stereo power what I didn't realise is that when I turned on the lights the power cut from that wire and became an earth if that makes sense so it was blowing all my fuses at night.
Something like this could be causing you grief?
Post Posted: Sat Oct 05, 2013 9:36 pm
if it became an earth the radio wouldn't work would it?
Post Posted: Sat Oct 05, 2013 9:42 pm
Was my first ever time :P
Just remembered it was the acc wire. Was a long time ago. With the ignition on it had power but when I switched the lights on the power no longer went through that wire. In the end It had something to do with the stock CD player and dash lights.
Post Posted: Sat Oct 05, 2013 9:44 pm
Yeah but your tailights still worked?
Post Posted: Sat Oct 05, 2013 9:51 pm
Blew my dash light fuse and something else but can't remember what.
What I'm getting at is check the constant power wire and the acc wire and make sure they are connected properly.
Post Posted: Sun Oct 06, 2013 8:19 am
This issue is a really easy fix. You need to connect the earth from the stereo directly to a metal part of the dash. The earth will currently be connected into the factory loom, this overloads the park light circuit
Vehicle: 1995 soft top vitara
Post Posted: Sun Oct 06, 2013 9:58 am
X2 had the exact same problem with another car I bought. Quick fix pompoms
Post Posted: Sun Oct 06, 2013 4:36 pm
fixed needed a different earth
Post Posted: Sun Oct 06, 2013 4:41 pm
You fixed it?
Users browsing this forum: No registered users and 164 guests
