It is currently Mon Nov 02, 2026 4:57 am
Vehicle: Suzuki
Post Posted: Sun Oct 20, 2013 7:50 am
I have a swb vitara and got done by cops for no modplate for body lift. I searched around but it's mostly before the new laws, the cop told me all I need to do is get blue plate and take paper work to dot and not have to go over pits. How would I get modplate approved do they simply write it out after checking it's safe or will it need to be put through tests. Cheers
Post Posted: Sun Oct 20, 2013 8:25 am
You just need to get an approved person to inspect and fit the blue plate.
Vehicle: Suzuki
Post Posted: Sun Oct 20, 2013 8:29 am
Ok cheers, what will they check on it? I have your body lift in it
Vehicle: Suzuki
Post Posted: Sun Oct 20, 2013 9:37 am
Also do you know approx price of body lift blue plates
Post Posted: Sun Oct 20, 2013 9:26 pm
Price depends on who you use, about $100 - $150. As the body lift is pretty simple there's not much to check, might just check size of the block matches the body rubber and the fasteners are high tensile.
Vehicle: Suzuki
Post Posted: Wed Oct 23, 2013 7:16 am
Ok cheers, just checked over it and found front left was loose. Pulled headlight out to tighten it and it's snapped flush with chassis. What is best way to get it out
Vehicle: 95 Leafy Sierra
Post Posted: Wed Oct 23, 2013 2:02 pm
How much thread is in the other side?
If it's long enough, get two locknuts tightened against each other or weld a nut to it and take it out from underneath.
Post Posted: Wed Oct 23, 2013 6:11 pm
Can you get a drill to it?
Vehicle: Suzuki
Post Posted: Wed Oct 23, 2013 11:18 pm
It is actually a tad down in the hole so no chance of grabbing it and the body is in the way to use a drill otherwise I'd use easy outs Have no idea how to pull it out
Post Posted: Thu Oct 24, 2013 6:47 am
Not sure on the vits, can you get to it from underneath?
Vehicle: Suzuki
Post Posted: Thu Oct 24, 2013 8:36 am
Nope only from top
Post Posted: Thu Oct 24, 2013 9:55 am
pretty sure you can access it from underneath... well you can on a SV vitara. :wink:
Post Posted: Thu Oct 24, 2013 5:10 pm
Only suggestion would be a pneumatic right angle drill or one of attachments for a power drill and get it from the top
Post Posted: Thu Oct 24, 2013 7:12 pm
Its a nasty problem. The way I've seen it done is to cut a flap out of the side of the chassis, weld a new nut in place and then weld the flap back up.
Post Posted: Sun Oct 27, 2013 9:52 pm
i had this happen with mine but it happened the 2nd back from the front on the drivers side (under pedals) had to cut a hole in the floor and cut the bolt out and weld in a new one. Shit house job.
Post Posted: Mon Oct 28, 2013 6:54 am
The fixed studs can be very problematic if they let go
Users browsing this forum: Google [Bot] and 84 guests
