It is currently Sat Oct 31, 2026 1:33 pm
Post new topic Reply to topic  [ 30 posts ]
Post Posted: Wed Oct 30, 2013 12:48 pm
IM looking at replacing all the non winscreen windows in a jeep to Lexan.
Anything i should watch out for.? also does anything know a cheap hookup or at least what a good price is?
thanks
Post Posted: Wed Oct 30, 2013 1:32 pm
Polycarbonate is what you want, lexan is brittle and can shatter
Vehicle: Which one?
Post Posted: Wed Oct 30, 2013 1:38 pm
Aren't they one and the same? i.e. Lexan is a type of polycarbonate?
I know what you are saying though. I have had lexan in drag cars before, but a drag car doesn't get knocked around anywhere near as much as a 4x4. Perhaps acrylic would be a better choice?
Post Posted: Wed Oct 30, 2013 1:41 pm
Sorry gotta bit mixed up. Lexan is a brand of polycarbonate.
Post Posted: Wed Oct 30, 2013 1:52 pm
lexan is used in bullet proof prison walls in QLD
Vehicle: 4wd
Post Posted: Wed Oct 30, 2013 2:14 pm
There would be different grades.
I'm sure the bullet proof stuff would cost a fuck load.
Watch out or you'll get sued.
Post Posted: Wed Oct 30, 2013 2:15 pm
yes, its also 12-16mm thick. the point is its not fragile
Vehicle: Which one?
Post Posted: Wed Oct 30, 2013 2:22 pm
Definitely not fragile. But it's not particularly "bendy".
Compared to glass it is superior in almost every way, however (price being the most obvious difference).
Post Posted: Wed Oct 30, 2013 2:29 pm
It scratches very easily and if on a road car can cause issues with road crash rescue
Post Posted: Wed Oct 30, 2013 2:40 pm
Its for the race jeep (unregisteres), it wont be on the drivers door or passenger door so no issues with crash rescue.
Post Posted: Wed Oct 30, 2013 3:58 pm
Poly scratches VERY easily and will be so bad that eventually you won't see clearly through it.
Check out old boat windscreens.
Post Posted: Wed Oct 30, 2013 4:05 pm
what about a layer of clear contact over it that can be replaced every few months
Vehicle: 03 Jimny
Post Posted: Wed Oct 30, 2013 4:08 pm
Yep scratches easy. I bought a front poly window for a sierra few years ago.
was about $200 so quite expensive. Destroyed it by putting my window wipers on.
Post Posted: Wed Oct 30, 2013 4:13 pm
http://www.quickpeel.com.au/
Post Posted: Wed Oct 30, 2013 4:34 pm
sounds expensive
Post Posted: Wed Oct 30, 2013 4:50 pm
Lexan is used in many offroad cars.
I think i saw the V8 super cars peel their windscreens off a couple of times during Bathurst.
Post Posted: Wed Oct 30, 2013 5:12 pm
Polycarbonate isn't very UV stable. We found this out with the trolley tug, which had polycarbonate flares for a while until they pretty much exploded from UV exposure. There is coated product which is better but IIRC it's only coated on one side. There is also product with a scratch resistant coating, again, I think only on one side. The scratch resistant coating adds quite a lot to the cost too.
Window tint film is quite scratch resistant, so some light film on the inside will help if you use scratch resistant polycarb with the scratch resistant side on the outside.
Just some thoughts. Poly windows look pretty rough quick in a car that goes bush.
Post Posted: Wed Oct 30, 2013 5:14 pm
Thanks Steve very useful
Post Posted: Wed Oct 30, 2013 5:24 pm
paid $280 18 months ago to replace the sides and rear window on the Sierra, didn't really shop around so could probably be got cheaper, scratches very easily, the rear is about 4mm or so and is held in by the rubber seal and is quite solid, the sides were only about 3mm and the way they mount means they flex a fair bit.
Post Posted: Thu Oct 31, 2013 8:25 am
i wonder about clear ish window tint film for outside where its most likely to get scratched.
Post Posted: Thu Oct 31, 2013 10:35 am
just get some clear UV window tint solves the UV problem and its clear so you can see through it
Post Posted: Thu Oct 31, 2013 11:34 am
Why not just weld in some mesh and don't worry about windows?
Post Posted: Thu Oct 31, 2013 12:47 pm
that has been considered aswell. just looking at all options
Post Posted: Fri Nov 01, 2013 6:49 am
What are windscreens for crappy jeeps worth??
Post Posted: Fri Nov 01, 2013 6:53 am
Cheap ish.
Post Posted: Fri Nov 01, 2013 3:53 pm
Why bother then, mine took a hell of a lot of punishment before it was unusable
Post Posted: Fri Nov 01, 2013 4:00 pm
we wouldnt be swapping out the windscreen any way. only the 3 windows down the sides and the rear tailgate window.
alot of the reason we considered it is weight. 30 kgs of glass up that high is a fair bit.
we might just pull it out and have thin plastic sheet to press stud on and keep the weather out.
Post Posted: Fri Nov 01, 2013 7:16 pm
Just ditch it and don't have anything
Post Posted: Sat Nov 02, 2013 6:27 pm
This is the stuff I used
To do this
Got this stuff from Bunnings a few years ago so I don't know if they still stock it.
I used the clear stuff on the top to let some light in and the grey on the sides.
Post Posted: Mon Nov 04, 2013 7:13 am
It's a rally, just run it. If you're looking out the back you're doing it wrong
Users browsing this forum: Google [Bot] and 328 guests
