It is currently Sat Oct 31, 2026 5:50 am
Vehicle: 96 Vitara 1.6 SWB
Post Posted: Wed Nov 06, 2013 5:03 pm
Hi there, I am having problems with my 1.6 EFI vitara. It isn't running well at all when cold and then gets better once it is warm. It has like a resistance when increasing revs, almost like a flat spot or its bogging down. It is running a little lean and the fuel pressure is at 2.2 psi and should be at 3.2. Possible things it could be is a faulty airflow meter, fuel pump, fuel filter, dirty injectors(not likely) or what else?
Has anyone had this issue? It hasn't been like this since I got it and seems to be getting worse. I just don't understand why it would run so bad when it's colder and them get better once at operating temp. It will get costly if I go changing out all parts and they not the cause. Spark plugs checked and fine.
Any advice would be much appreciated.
Post Posted: Wed Nov 06, 2013 7:15 pm
Fuel pressure is critical.
Post Posted: Wed Nov 06, 2013 7:23 pm
and it's WAY higher than 2.2 or 3.2 psi.
It's more like 45 psi.
Post Posted: Wed Nov 06, 2013 8:02 pm
I'd start with changing the fuel filter.
Vehicle: SWB Sierra
Post Posted: Wed Nov 06, 2013 9:22 pm
Guessing OP meant bar, not psi.
3.2b = ~46psi :wink:
Vehicle: 89 Sierra Widetrack
Post Posted: Thu Nov 07, 2013 6:38 am
Dirty injectors maybe. I spent a month trying to track down a similar issue on my old jackaroo.
Can make a little cleaning station at home for $4. Just need a couple of cheap plastic syringes.
Check out YouTube
Vehicle: 85 ' Drover
Post Posted: Thu Nov 07, 2013 7:47 am
How are you measuring the fuel pressure?
If its a guage while the car is running, you should see the pressure change a bit with throttle opening. (fuel pressure regulator doing its thing)
2.2 bar is about 31psi, which is a bit low if its supposed to be 3.2
Also how do you know its running lean?
Users browsing this forum: No registered users and 447 guests
