It is currently Mon Nov 02, 2026 8:47 am
Vehicle: 2013 JImny
Post Posted: Thu Nov 14, 2013 7:12 pm
Hi peoples ,i put some springs in the jimmy couple weeks ago and had a look today seem to have shifted abit at the bottom i think,first time doing this and wanted to know if they have to be right up against the edge of the bottom mount ledge thingy,
any help or advice ? Not sure if it matters or not
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Nov 15, 2013 7:14 am
they will do that, and will get a bit noisy when flxing. its nothing to worry about they typically dont move much further then that.
Post Posted: Fri Nov 15, 2013 7:22 am
X2. Normal and nothing to worry about.
Vehicle: 2013 JImny
Post Posted: Fri Nov 15, 2013 7:42 am
thanks guys
Post Posted: Fri Nov 15, 2013 8:05 am
It's probably happening because those aftermarket springs are slightly shorter than standard springs. Often, lift springs are a little bit shorter when out of the vehicle due to design parameters, and this will mean they can go a little bit loose on full flex, which will cause them to move around a bit.
Vehicle: 2013 JImny
Post Posted: Fri Nov 15, 2013 8:33 am
thanks for the info ,heres pic of comparison to stock just for reference
Post Posted: Fri Nov 15, 2013 8:47 am
Bit hard to see, but it does look that the new springs are slightly shorter.
Users browsing this forum: Google [Bot] and 52 guests
