It is currently Sat Oct 31, 2026 3:43 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2  Next
Vehicle: 2006 Z Series Jimny
Post Posted: Mon Sep 02, 2013 4:15 pm
Hi,
The wet season is fast approaching and i want to load a set of muddies for my wet season weekend wheeling. Anyone know of a (available in Australia) tire that will out-mud the Hankook DynaPro RT03 MT in the 215/75/R15 size.
Here is my spiel on my current (soon to be dry season only tires)
Dueler A/T D697 in 225/75/R15
I've been running Dueler A/T D697 in 225/75/R15 for the last 4 months and really like them. I've adjusted well to the higher gear ratios the 225's presented on my Jimny, a little extra clutch here and there but Its been fine for me. Put them through plenty of rocky trails and the like and think they are proving very reliable. They are wearing really slow, have been great on sand, rocks and everything except thick, sticky mud. Amazing I can't find any chips and I've been running them at high pressures (40psi).
Post Posted: Mon Sep 02, 2013 4:51 pm
bfg and silverstones list that size
Post Posted: Mon Sep 02, 2013 4:52 pm
silverstones extremes are gonna be the best mud bogging tyre
Post Posted: Mon Sep 02, 2013 6:08 pm
BFG MT's?
Post Posted: Mon Sep 02, 2013 6:30 pm
Scrawn wrote:
BFG MT's?
Second that, i've been running this size BFG MT's on my coily sierra for some time now and have no complaints.
Post Posted: Mon Sep 02, 2013 6:54 pm
I really like the Federal Couragia M/T's. Kyzer will agree. He just bought a new set to replace the old.
Post Posted: Mon Sep 02, 2013 6:59 pm
I am not sure that Couragias come in 215's
Post Posted: Mon Sep 02, 2013 10:41 pm
40psi?? What???? Re you joking or do you actually run that pressure on your tyres? O.o
Vehicle: 2012 jimny
Post Posted: Mon Sep 02, 2013 10:42 pm
For the price my hankook mt's have been great!
Post Posted: Mon Sep 02, 2013 11:42 pm
austuff wrote:
Amazing ...................I've been running them at high pressures (40psi).
:shocked: :rofl:
Vehicle: Coil Sierra
Post Posted: Tue Sep 03, 2013 5:45 am
40psi thats twice as much as what i put into my 31 BFG MT
Post Posted: Tue Sep 03, 2013 8:25 am
Thanks for all the inputs, muddies to price and review so far then:
BFG MT
Silverstone Extremes
Hankook RT03
Federal Couragias (If I can find in 215's)
As per my inflated tire inflation:
I've pretty much kept with the stock pressure since getting them fitted, guess I should stop being slack and get with the flow and start letting them down for scrub. I just hate waiting for the "slow as hell" little compressor to pump them back up :) Guess I should get a bigger one.
Post Posted: Tue Sep 03, 2013 8:32 am
stock pressures are NOT 40psi
Post Posted: Tue Sep 03, 2013 8:33 am
Stock pressure is 22psi on my Vitara, I run 26 on road.
8-15psi off road.
My slow cheap compressor pumps to 20 fairly quick, anything over that is too slow.
But 20 is fine to get to a servo.
I'm sure most zooks are 22psi at a guess
Post Posted: Tue Sep 03, 2013 8:36 am
google tells me 26psi
Post Posted: Tue Sep 03, 2013 8:47 am
Which is based on a very lightly constructed 'P' tyre. Optimum pressure in a much stiffer LT tyre might be less than the placard, although not by much.
You're not getting anywhere near the most out of any tyre if you're not airing it down.
Post Posted: Tue Sep 03, 2013 8:52 am
I'll have to double check but pretty sure they were inflated to 40 (or maybe between 38-40). I am talking the Dueller 697's AT's (225/75/15) I currently have on
Post Posted: Tue Sep 03, 2013 8:56 am
you should probably be looking at about 20 for those on road
Post Posted: Tue Sep 03, 2013 9:00 am
Well who ever did that was ignorant of what the pressures should be. You should be running low to mid 20s. Find what works best for you.
Post Posted: Tue Sep 03, 2013 9:04 am
I put 40 in newly fitted tyres, for a week, to make sure beads are nicely seated.
Maybe fitter pumped them till they seated, and left it at that.
My recent tyres had 52psi in them after fitting.
Post Posted: Tue Sep 03, 2013 9:07 am
I will check current pressure then try say 23psi this arvo, but must say that it does drive well on the road as is. Could the higher pressure attribute to what I think is very low wear over the last 4 months or so, they don't appear to have worn at all (still have the new spare to compare to).
Post Posted: Tue Sep 03, 2013 9:15 am
i would say at 40 the wear would be right up the middle of the tyre, (uneven wear)
i doubt that the pressures would stop them wearing, just good compound
Post Posted: Tue Sep 03, 2013 9:18 am
Light car, tyres last very well on Zooks.
Higher pressures will wear out centre tread faster,
and too low will wear outer edges of trad faster.
High pressures can cause skids on wet roads also.
Vehicle: Suzuki Jimny 2013
Post Posted: Tue Sep 03, 2013 11:37 am
When I got my new Suzuki I was shocked to find the dealership had put over 40 psi into the tires..
The placecard says 26 rear, 23 front, and 29 rear when fully loaded. (Suz Jimny 2013)
Post Posted: Tue Sep 03, 2013 7:53 pm
What he said ^^
Just open your door and check the placecard. It says those figures
4 months is nothing, dependin on how much u drive it wont be close at all to start seeing some wear. Give it at least year and half to have something really notisable at plain sight. And by them it would be already too late.
I never pass the 26-30psi mark and some how manage to wear down right in the middle of the tyre mostly on just two of them. Also a lack of constant rotattion also helped. But now im facing having to buy new tyres pretty soon instead of in a few months
Most tyre places would pump the tyres till 35-40 as becose "its a 4wd". So dn trust them. I have only had 1! Place where they actually put 25 on them. Last week I change my rims and the idiot put 37 on them and didnt even needed to check it to know, the car feel like shit. Very loose steering and pretty bumpy on the highway till i stop in a servo to air down.
No idea on why you say you like the handling, but stop in a servo and air down to 24 and youll see clouds and rainbows then hahaha
Vehicle: WT sierra, GU CRD
Post Posted: Tue Sep 03, 2013 8:25 pm
BertZook wrote:
What he said ^^
I'd say they would do it to seat the bead etc. It would take them time to let it back down and why would they? Its not hard to let them down to where you want it. As for trust it is not like they stole your lunch money.
Jeez, that idiot
Handle like shit anyway
Next tyre change I might ask to have a sh*t and get complimentary wiping.
I love ZD30. :)
Post Posted: Tue Sep 03, 2013 8:28 pm
Hmm, I'm not convinced the physics supports this view.
However, excessively low pressures definitely reduce braking traction, and here's the proof: Next time you see braking skid marks on a road have a look to see if they look really dark on the outside edges and faint in the centre. That's the effect of under inflated tyres - the centre of the tread is folding up under braking load and coming away from the road surface. Needless to say that's hurting braking traction.
Post Posted: Tue Sep 03, 2013 8:38 pm
A friend of mine went on a driving techniques course, I think organised by Skoda. The instructors said 90% of people run too low of a tyre pressure, too low is every bit as bad as too high.
I love ZD30. :)
Post Posted: Tue Sep 03, 2013 8:40 pm
I like the handling, she drives in a straight line if I let go of the wheel, no death wobbles anymore, i can scoot around a roundabout if i need too, don't get me wrong doesn't compare to my sedan but much better than my old land rover :)
Will seriously get round to dropping pressures tomorrow though to get up amongst those
clouds and rainbows
cheers
Vehicle: 08 jimny
Post Posted: Tue Sep 03, 2013 8:44 pm
Pretty sure you can get couragias in a 235 aswell They Would be a similar size as your 225s Becuase they have a skinny tread pattern
Users browsing this forum: No registered users and 414 guests
