It is currently Fri Oct 30, 2026 2:45 pm
Vehicle: 1996 Leaf Sierra - Soft Top
Post Posted: Sun Nov 24, 2013 5:04 pm
Basically the revs drop when I go up steep hills until the car just conks out.
If I let my Sierra sit for 10 mins and start it back up it's all good and goes again perfectly fine.
Someone told me there could be something that blocks the carby when the car is at a certain angle.
Really want to get this fixed as I can't really go wheeling because of it!
If anyone has had this problem or knows how to fix it I would muchly appreciate any information and help.
Thomas.
Vehicle: 4wd
Post Posted: Sun Nov 24, 2013 5:22 pm
Start simple.
Check the fuel pump first. Fit a fuel filter between the pump and the carby. When it dies, check the filter. If the filter is dry then the fuel pump is struggling to supply sufficient fuel under load.
Watch out or you'll get sued.
Post Posted: Sun Nov 24, 2013 5:39 pm
Is it the stock carby?
Vehicle: Which one?
Post Posted: Sun Nov 24, 2013 5:42 pm
That was going to be my question. If it's a webber, well there's your answer: it's a webber.
Vehicle: Drover pickup turk
Post Posted: Sun Nov 24, 2013 6:25 pm
I had this happen when I first got mine, Swapped out the old fuel filter for a new one and gave the carby a good spray with carby cleaner and she was all good.
May or may not work for you.
I like the tuna here
Post Posted: Sun Nov 24, 2013 7:19 pm
Hahaha no not a webber. It's stock.
Okay I'm going to put a new fuel filter in. And carby cleaner it. And see how it goes!
Vehicle: Which one?
Post Posted: Sun Nov 24, 2013 7:25 pm
Seriously though, if (and when) it happens again, do this:
Post Posted: Sun Nov 24, 2013 7:34 pm
Yeah I'll do all of the cleaning and new stuff first and then if it does die again (touch wood) I'll make sure to check it!!
Thanks!
Vehicle: Vit98 J20A SWB & Sierra89
Post Posted: Wed Nov 27, 2013 10:46 pm
Check for a blocked vent in the fuel tank. I had a stoopid R sole wasp lay some of that clay stuff in a fuel vent/breather and coz air couldnt get in to replace the fuel being used, it used to slowly die.... then come good. Try loosening the fuel cap and if that fixes the problem, look for the fuel tank vent and clear it out.... If yours vents thru a canister, look there for blockage
Otherwise, as others said, fuel pump, fuel filter or water/crud in fuel. Prolly go for an electric fuel pump to make sure it wont stop just at the most inconvenient time.....
Post Posted: Thu Nov 28, 2013 11:38 pm
Okay great thanks. I'll get searching once I'm back home.
Can anyone recommend a fuel pump? And it it a easy thing to instal? Or anything that you can warn me about?
Thankyou!
Vehicle: WT sierra, GU CRD
Post Posted: Thu Nov 28, 2013 11:45 pm
Thankyou!
Just go into a repco or similar and get one. I got "goss" brand. Seemed ok.
You might get oil everywhere doing it, so get degreaser too, just make sure the steel 'finger' for lack of a better word engages properly.
I love ZD30. :)
Post Posted: Fri Nov 29, 2013 3:23 pm
Okay sure thing. Thankyou.
Post Posted: Sat Nov 30, 2013 2:43 am
Facet are ok, but a bit expensive.... try ebay or wreckers?
Edit: Lots on ebay for under $30 delivered. The gold coloured 'universal' cube looking ones look the same as facet pumps. You only need low pressure, medium volume. One of those would keep you out of trouble
Post Posted: Sat Nov 30, 2013 3:48 pm
Sorry don't want to ask for to much, but would you be able to link me to the eBay pump you'd recommend?
Post Posted: Sat Nov 30, 2013 10:49 pm
Mine is a weber, pretty much faultless.
Dunno why people bag webers so much, they are a great carby.
Post Posted: Tue Dec 03, 2013 8:13 pm
Sorry dont know how to put links on here. Just look on ebay for 'electric fuel pump' plenty to choose from. I found the gold coloured cube ones (same as facet) seem good at around $30
The last one I bought was before I discovered ebay, I payed $110 for the same thing :evil:
Post Posted: Tue Dec 03, 2013 9:17 pm
Why would you want to complicate things further by adding an electric pump? Just get a new stock mechanical one and call it good for another 200000ks....
Vehicle: Which one?
Post Posted: Wed Dec 04, 2013 8:22 am
^^ This. I once swapped out a $400 Mallory electric pump for a $12 mechanical in my drag car to iron out some gremlins. Sure, the mechanical might have "technically" started to run out of puff over 7000rpm but the limiter was set at 6800 so it was never going to be an issue. The Mallory is still sitting in my shed and the 12-buck pump is still kicking ass.
Vehicle: vit1990
Post Posted: Wed Dec 04, 2013 8:33 am
How did you work out it's the fuel pump?
Post Posted: Wed Dec 04, 2013 1:45 pm
Yeah I'm liking the idea of a cheap stock mechanical one...
And I haven't been home to look at my car, 2 more weeks and I'll do this.
But I'll do a full service to the car and if the fuel pump isn't to expensive I don't see why not to put a new one in... Car has done around 130000kms, it's probably due for one anyway! Even if it's not the problem.
Thanks
Vehicle: jimny/gsxr600
Post Posted: Sat Dec 07, 2013 1:23 pm
dont they have a common fault with these carbs that the venturi gets blocked off and causes the exact problem you describe,
im pretty sure acme sell one for like 5 bucks to fix it for good.
Love how people are like "START SIMPLE"
then give a complicated solution haha
Post Posted: Sat Dec 07, 2013 1:24 pm
http://www.rocky-road.com/samurai-carbu ... nturi.html
Vehicle: SJ80, SE416
Post Posted: Sat Dec 07, 2013 1:42 pm
driftke70 wrote:
http://www.rocky-road.com/samurai-carburetor-venturi.html
I have 2 of these. They are to suit US models which have a Hitachi carby - they are unsuitable for Australian models! They don't even come close to fitting!
Also, if you have a look at an australian model carby it already has a short pipe sticking out of the carby body...
Here is my thread from NBS about this part:
http://nbs4x4club.com/forum/index.php?topic=13969.0
Vehicle: 4wd
Post Posted: Sat Dec 07, 2013 2:20 pm
What's complicated about adding a fuel filter between the fuel pump and the carby?
Probably less complicated than your suggestion of purchasing a part from overseas, then trying to fit said part to an in compatible carby. :?
Users browsing this forum: Google [Bot] and 413 guests
