It is currently Tue Oct 27, 2026 1:11 am
Vehicle: 2008 jimny sierra
Post Posted: Fri Dec 27, 2013 11:21 am
Hi i went to get in my 08 jimny today. firstly the central locking wouldnt work. i then started the engine and the check engine light stayed on. then i noticed i had no power to the stereo. i turned engine off to check fluids. oil was full but noticed there were little air bubbles. then checked the radiator, over flow bottle empty and also tank. i had done a 2 hour drive the day before and i checked all fluids before i left and all was good. iv had the car for over a year and never even had to top up the radiator fluid. the temp never rose any higher than normal when i got home from the 2 hour drive everything seemed normal. im completely stumped as to what has happened or how i can fix the problem. and help would be greatly appreciated
Post Posted: Fri Dec 27, 2013 11:45 am
i have topped up radiator and run the engine with the heater on. thermo fan comes on and off as normal so im guessing the the thermostat is working and temp sitting at normal temp. no bubbles in engine oil but check engine light still on and no central locking or radio and when i turn engine off taco stays at about 750rpm
Vehicle: Sold zuk got a Bt50
Post Posted: Fri Dec 27, 2013 12:53 pm
Checked fuses ? In 1 of my old Holden cars did weird things when the tail/brake light fuse blew
Post Posted: Fri Dec 27, 2013 2:57 pm
yeh checked every fuse. stereo was blown but everything else was good
Post Posted: Fri Dec 27, 2013 3:48 pm
Kinda sound's like a bad body earth.
Post Posted: Fri Dec 27, 2013 4:49 pm
ok how do i try fix that? cheers mate
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Dec 27, 2013 7:49 pm
Check ur terminals on ur battery also
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Dec 27, 2013 9:39 pm
You should read the engine fault codes and see what came up. Best way is to get an OBD Bluetooth dongle from China and the Torque app on a smartphone. The engine fault codes might give you a clue as to what is going on. Someone in Brisbane might have one and be able to give you a hand with that.
Post Posted: Sat Dec 28, 2013 3:58 am
The back up power for the ECU is taken from the same feed as the radio, if its not present then you will get a Check Engine Light warning, I would suggest that you double check the fuse on that circuit. Does the interior light work? that's usually on the same circuit as well.
Post Posted: Sat Dec 28, 2013 8:36 am
i replaced the blown fuse yesterday and it has blown again. i checked the earth and its solid. the radio, interior light, key in ignition beeper and the central locking are all not working. any ideas on what could be shorting it out? :( thanks everyone for your support
Post Posted: Sat Dec 28, 2013 9:31 am
Start looking for short's in anything that's not working, Int light is a good start.
Have you had anything fitted to it lately??
Post Posted: Sat Dec 28, 2013 11:17 am
only thing electrical was the stereo but that has been in for nearly a year. i did get a 3" lift snorkel and k&n filter about 2 months ago. must b something to do with the long drive. its got me stumped. ill turn int light and stereo of and see if the fuse still goes. not really sure what else to try. looks like suzi is going to the mechanics :(
Post Posted: Sat Dec 28, 2013 11:20 am
yeh i checked the terminals and the earth and everything seemed spot on.
Post Posted: Sat Dec 28, 2013 4:39 pm
ok so i tuned off the int light and replaced the fuse... now everything is working fine and no check engine light! wtf??? would it just be the bulb?
Post Posted: Sat Dec 28, 2013 6:25 pm
pull the cover off the light and see what falls out
Post Posted: Sun Dec 29, 2013 9:47 pm
yeh so i opened the light, unplugged it, pulled the bulb out and then put it all back together again and everything is back to normal! im still abit confused as to what happened but its all good now. thank you everyone for your help. i put the awning on today and off too bunbury tomorrow. im having trouble uploading pics. no matter how much i re size them they r still over the 19kb?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jan 01, 2014 7:53 am
Photo bucket and post the image codes to imbed photos in your post.
Mabie check the wiring out behind the light mount Look for a dead short.
Post Posted: Sun Jul 13, 2014 9:38 pm
update... it was the heater core split. steam shorted everything out. replaced heater core (pricey) luckily didnt stuff computer. all is good now. waiting to put 1.8 and lockers in....
Users browsing this forum: Google [Bot] and 336 guests
