It is currently Fri Oct 30, 2026 12:49 am
Vehicle: 1992 suzuki sierra
Post Posted: Wed Feb 26, 2014 8:08 am
Hi Guys
Need to replace this soon checked Exedy's clutch finder and came back with the following two options for the input shaft spline.
Flywheel Profile -2.1mm
Size 190
Spline OD 22.4
No. of Teeth 20
Flywheel Profile Flat
Size 190
Spline OD 19.1
No. of Teeth 18
Clutch industries only had one option for the sierra under SJ413
Clutch plate dimensions (mm): 190 x 20T x 22.8
So which one is correct? From What I can find is 84-90 and 97-99 use the same clutch but can't find any confirmation for my 92.
Thanks
Guys
Post Posted: Wed Feb 26, 2014 3:13 pm
Anyone at all know???
zedboy wrote:
Hi Guys
Size 190
Spline OD 22.4
No. of Teeth 20
Size 190
Spline OD 19.1
No. of Teeth 18
Thanks
Guys
Post Posted: Wed Feb 26, 2014 3:42 pm
mine's a 92 and it takes the same clutch as a jimny, try a search for jimny and it should match one of the above part numbers.
Vehicle: Coil Sierra
Post Posted: Wed Feb 26, 2014 6:45 pm
Ive always used the SZK6474 (20 teeth) 96 coil model g13ba
From clutch industries
Post Posted: Sat Mar 01, 2014 9:51 pm
My sierra is a 92 and it has a stepped flywheel.
Users browsing this forum: No registered users and 163 guests
