It is currently Fri Oct 30, 2026 12:48 am
Post Posted: Sat Mar 01, 2014 11:51 am
Will a 99 gv Ecu work as a spare for an 04 gv? Same size engines as all that.
Post Posted: Sat Mar 01, 2014 2:34 pm
No. I believe the engine map is different. Early gv was 106kw. Later models were 130kw.
Post Posted: Sat Mar 01, 2014 3:10 pm
Yea thought so. So would it need an +03 model to work?
Post Posted: Sat Mar 01, 2014 5:40 pm
Is yours on the fritz?
Post Posted: Sat Mar 01, 2014 7:22 pm
Nope mines fine just on the look for a spare for the future if it ever dies or gets wet. Not actively looking but found a wreck going cheap
Post Posted: Sun Mar 02, 2014 2:15 am
Its a different ECU, I don't think that it even has the same connectors.
Post Posted: Mon Mar 03, 2014 7:34 pm
if you have an 03 SQ625 with manual transmission then you will have a 33920-52J40 or 41 or 42 ecu (they superceeded the part numbers over the years) , i get at least a call a day for this ecu , and last week i got 6 calls in 2 days !!! i have sold a brand new ecu for one last week for $2200 which was still cheaper than any dealer can offer . they suffer from the same problem they all do , the ac leaks on them and fries them.
Rhinoman , i have been told by a local ecu repairer that they cannot repair them successfully , is this true ? pm me if you have them available for sale . i can keep quoting new units but if i can offer a cheaper alternative then thats great .
Suzuki surprisingly tells me they have not sold one for years and they are ex japan . well i broke their mould ..
Post Posted: Mon Mar 03, 2014 8:51 pm
What make of ECU is that? The Hitachis have a tendancy to self destruct and I've never seen one with a metal case that wasn't rusty.
Post Posted: Mon Mar 03, 2014 8:52 pm
Got any dead ones for me?
Post Posted: Mon Mar 03, 2014 11:53 pm
My friend with a 99 had his ECU die and his Auto electrician put in a second hand one from some daihatsu and it worked. I have my air con running all the time and the water flows out the drain hole to the outside on the passengers side... $2200 is stupid money for one you could almost get a custom one that can be tuned for that money.
Users browsing this forum: No registered users and 182 guests
