Vehicle: 1996 swb Vitara Soft top
Posted: Sun Mar 02, 2014 9:10 am
Just picked up a cheap 1996 Vitara & when I bought it only did a quick inspection on engine & it was a 16 valve so I thought --OK its a 16B However when I go through blue slip procedure to register find a different engine number & mechanic tells me its actually a 16V G16A!! No problems with registration ,engine not stolen etc & vehicle passed & now registered. Appears one of the previous owners may have put a later model Jap 16v G16A in.??? Engine had been reconditioned by the guy I bought it off--crankshaft grind,new pistons bearings,hone block/head,machine flywheel,recondition head etc But all the receipts he gave me refer to G16B.??? Question --are the 16 valve G16A engines the same as the earlier G16B, I want to fit extractors & not sure if I require extractors for G16A or G16b??? Cheers Dusty
Users browsing this forum: Google [Bot] and 330 guests
