It is currently Fri Oct 30, 2026 4:55 pm
Vehicle: 1996 Leaf Sierra - Soft Top
Post Posted: Wed Mar 12, 2014 9:22 am
Just got my flywheel machined and it's time to put everything back together. So I was just wondering what I should set the torque to on the bolts that hold my sierras flywheel down.
If anyone knows that would be great!
Thomas.
Post Posted: Wed Mar 12, 2014 10:52 am
FT... Armsup
Post Posted: Wed Mar 12, 2014 12:06 pm
That's what I'm considering. Hahahahaha
Vehicle: SWB Sierra
Post Posted: Wed Mar 12, 2014 12:40 pm
Have a look in the service manual at suzuki info, should be pretty easy to find
Vehicle: 92 wt soft top sierra
Post Posted: Wed Mar 12, 2014 3:24 pm
I just had a look in my suzuki workshop manual and it says
Flywheel bolt 57-65Nm or 41.5-47lb-ft
Post Posted: Wed Mar 12, 2014 5:15 pm
Alright thanks fellas
Vehicle: '94 suzuki maruti
Post Posted: Wed Mar 12, 2014 5:25 pm
i used a rattle gun and loctite... i had the bastards come loose about 20km down the road without the loctite.
Post Posted: Wed Mar 12, 2014 5:32 pm
Yer dont trust your rattle gun always double check with a spanner
Post Posted: Wed Mar 12, 2014 6:24 pm
Never had an issue with just a rattle gun, although mine is a good one
Vehicle: 85 ' Drover
Post Posted: Thu Mar 13, 2014 8:46 am
Use a torque wrench and torque it to the spec.
A rattle gun should only ever be used to undo things, never to do them up.
Post Posted: Thu Mar 13, 2014 10:36 am
What??!! :? :roll:
Post Posted: Thu Mar 13, 2014 4:11 pm
What he said^^
Abd thanks for that killazook! Hopefully get it all in tonight!
Post Posted: Thu Mar 13, 2014 8:24 pm
There is a specific torque for the fly wheel bolts given by Suzuki. Use a torque wrench to do it up so then you know its correct.
The issue with rattle guns is that you have no idea how tight its been done up. And too me "f'n tight" is not good enough for a ~7kg weight spinning at 6000 rpm 300mm from my ankles.
Post Posted: Thu Mar 13, 2014 9:49 pm
i've seen quality rattle guns clean snap high tensile bolts. no reason it cant do flywheel bolts tight enough
Post Posted: Thu Mar 13, 2014 9:53 pm
Yeah, I was asking what torque I set them too! Which I have now found out!
I'm sure a rattle gun could do the job just fine. But I would rather set it to the specific torque.
Post Posted: Fri Mar 14, 2014 6:18 am
I'd rather not have snapped bolts on my flywheel either.
The torque setting is there so that it's tight enough for the bolt to do its job but not too tight to damage the bolt or thread.
Once again a rattle gun you have no control over high tight or loose it is.
Post Posted: Fri Mar 14, 2014 7:06 am
I'm pretty sure that the service manual states to use a thread lock on those bolts.
Post Posted: Fri Mar 14, 2014 8:02 am
Yeah I'm going to torque it up and use thread lock. Just an extra precaution I guess.
Users browsing this forum: No registered users and 410 guests
