| Author |
Message |
Sco-tie
Joined: Fri Apr 06, 2012 5:02 pm Posts: 928 Location: Adelaide hills!
Vehicle: 04 Grand Vitara, 2.5L, V6
 Posted: Mon Mar 17, 2014 4:29 pm |
Apparently dynamic 'd' shaped hole 16x8 rims will fit the 98-04 GV and clear the calipers. They said they only go to -10 but i have seen others the same going to -13 still d shaped holes and 16x8. I've ordered a set to test fit and will only believe they fit when i see it. Any one know for sure why the tyre shop would only say they go to -10 but i can see them online to -13?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Mon Mar 17, 2014 5:24 pm |
Are you going to notice a 3mm difference in offset?
Sco-tie
 Posted: Mon Mar 17, 2014 5:30 pm |
doubt you would unless its the difference between scrubbing on the chassis or not
Gwagensteve
 Posted: Mon Mar 17, 2014 5:38 pm |
I bet it isn't the difference.
3mm at a 29 degree angle is 5/8 of 3/4 of nothing.
Sco-tie
 Posted: Thu Mar 20, 2014 4:58 pm |
No surprise that they didn't fit, Not even close! Thats that settled if anyone tell you so.
GeckoXL7
Joined: Tue Sep 25, 2012 8:12 pm Posts: 1173 Location: VIC
Vehicle: 2002 Suzuki XL7
 Posted: Fri Mar 21, 2014 9:36 am |
I got quoted 16x7 -13 Dyamics 130 each. Dynamic said they will fit, this is good to know.
There is a special on ROH Track2 16x7 for 89 each at bobjayne at moment
Sco-tie
 Posted: Fri Mar 21, 2014 10:24 am |
Nothing bob Jane have in a 16 will fit. Dynamic probably have them as fitting 2l gvs
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Fri Mar 21, 2014 10:30 am |
Sco-tie wrote: Dynamic probably have them as fitting 2l gvs I wasn't even aware the brakes were different on the 2L GVs. Does my shorty have 1.6 brakes on it or something?
Sco-tie
 Posted: Fri Mar 21, 2014 11:08 am |
I think the swb have the small breaks. I think the 2l ones some have large and some small don't quote me on it. The smaller breaks allow you to run 15 in rims
henno
Vehicle: Which one?
 Posted: Fri Mar 21, 2014 11:19 am |
Sco-tie wrote: The smaller breaks allow you to run 15 in rims This would please me in all sorts of ways. Time to get my hands on a 15-incher and give it a whirl. Giggity.
zoukshin
Vehicle: 2004GV + bar + custom mods
 Posted: Fri Mar 21, 2014 11:35 am |
Not sure what that engine is, but that swb definitely can fit 15" rims.
Sco-tie
 Posted: Fri Mar 21, 2014 11:37 am |
And kiwi has 15in on his swb
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Fri Mar 21, 2014 6:23 pm |
Only the SWB 1.6 GV's have the older Vitara brakes. Everything else AFAIK has the bigger brakes.
henno
Vehicle: Which one?
 Posted: Fri Mar 21, 2014 6:46 pm |
The one pictured above is definitely a 1.6, so that explains that.
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Sat Mar 22, 2014 4:22 pm |
Sco-tie wrote: Nothing bob Jane have in a 16 will fit. Dynamic probably have them as fitting 2l gvs If anything id say they might be for SV vitaras
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
Sco-tie
 Posted: Sat Mar 22, 2014 4:55 pm |
But sv borstals aren't gvs and that's what they have it listed for. Why do so many places think there is no differences between vits and gvs...
Built4thrashing
 Posted: Sat Mar 22, 2014 6:44 pm |
Sco-tie wrote: Why do so many places think there is no differences between vits and gvs... Coz they are retarded common whore faclon parts retailers
