| Author |
Message |
Bushie
Vehicle: 1997 Suzuki Sierra JX
 Posted: Tue Mar 25, 2014 10:50 am |
Hi all,
Just been told by ARB dealer that they don't make Safari snorkel for the 1997 Sierra. Apparently cuts off at Dec '96? Anyone recommend another supplier and a place in Sydney that would fit it? Same goes for a lift.
Apparently Sierra had a face lift (including different shocks?) and forgot to tell ARB.
Cheers!
Rob.
greenzook89
Joined: Sun Sep 06, 2009 11:30 pm Posts: 2591 Location: Ipswich
 Posted: Tue Mar 25, 2014 11:36 am |
Yeah you will find yours is a coily with the nicer more rounded front. Very few manufactures bothered making stuff for the coil Sierra as they were only on the market a couple of years.
Some leafy parts do fit. Have a squiz thru some build threads to get some inspiration.
_________________ 31zook wrote: Makes me want something similar
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Tue Mar 25, 2014 11:50 am |
A snorkel on a Sierra is a pretty pointless exercise anyhow (the distributor is afraid of water), but there are plenty of Coilies with snorkels fitted. ARB's average fitter doesn't have either the expertise or knowledge to make anything fit but it can be done.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Tue Mar 25, 2014 1:33 pm |
^this.
Sierra intakes aren't vulnerable to water ingress. Electrical breakdown will stop progress well before water can get into the intake.
Fit one if you really want, but snorkels on sierras edge close to roof lights and high lift jacks to me.
Trebor
Vehicle: Suzuki Sierra 1996 Coily
 Posted: Wed Mar 26, 2014 3:47 pm |
hey TJM makes one to fit from memory
Trebor
 Posted: Wed Mar 26, 2014 3:55 pm |
coily96
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
 Posted: Wed Mar 26, 2014 6:50 pm |
Its just a listing error, the safari pre 1996 will fit. The only issue is the rh guard flasher has to be moved. Here is a safari knock off one fitted to a 1996-1999. It even bolted straight up to the airbox with the hose and clamps they supply.
Bushie
 Posted: Wed Mar 26, 2014 7:37 pm |
Thanks to all for your replies. Coily96 it appears you're correct - I called the head office and they confirmed.
Now just have to work out if / should I get a lift done...
Bushie
 Posted: Wed Mar 26, 2014 7:42 pm |
Also thanks for the link Trebor - they're have a store pretty close to me so I'll check them out for sure.
Trebor
 Posted: Thu Mar 27, 2014 12:05 am |
no problem, though me personally Id get the TJM because there you don't have to remove the indicator where with the safari you do
Trebor
 Posted: Thu Mar 27, 2014 12:09 am |
You should also have a look at my build thread if you are thinking about lift kits
