Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
Posted: Fri May 02, 2014 4:35 pm
Ok so I'm trying to fix up the front suspension a bit in the GV and need to sort the issue with the front drivers inner CV pulling out of the side gear slightly on full flex
I know the SE Vitara shafts are smaller and have a different spline count on the diff. (22 spline)
And I know the SV420/620 have a 26 spline inner and are slightly longer in the spline/bearing shoulder.
As I have a lockright fitted to the front I need this longer inner cv to get it to lock into the diff side gear.
What im trying to find out is will a SV Vitara CV shaft be a straight swap for the GV with the lockright?
Is the length from oil seal to oil seal on the inner and outer cvs the same?
Can someone take and post a photo of a GV shaft besides a SV Vitara shaft and post it up.
I can get new SV shafts for $135+GST new but want to make sure it will fit before ordering.
Or does anyone near me have one I can borrow to see if it fits.
Users browsing this forum: Google [Bot] and 311 guests
