It is currently Thu Oct 29, 2026 4:05 pm
Post Posted: Fri May 02, 2014 4:35 pm
Ok so I'm trying to fix up the front suspension a bit in the GV and need to sort the issue with the front drivers inner CV pulling out of the side gear slightly on full flex
I know the SE Vitara shafts are smaller and have a different spline count on the diff. (22 spline)
And I know the SV420/620 have a 26 spline inner and are slightly longer in the spline/bearing shoulder.
As I have a lockright fitted to the front I need this longer inner cv to get it to lock into the diff side gear.
What im trying to find out is will a SV Vitara CV shaft be a straight swap for the GV with the lockright?
Is the length from oil seal to oil seal on the inner and outer cvs the same?
Can someone take and post a photo of a GV shaft besides a SV Vitara shaft and post it up.
I can get new SV shafts for $135+GST new but want to make sure it will fit before ordering.
Or does anyone near me have one I can borrow to see if it fits.
Vehicle: 99 Grand Vitara
Post Posted: Fri May 02, 2014 6:23 pm
If I remember correctly they are the same because the SV is wider than the SE. 90% Sure it will be a straight swap over.
http://www.strictly4x4.com.au
Post Posted: Fri May 02, 2014 6:32 pm
Hope so....... will do some more digging before I spend the coin.
Post Posted: Fri May 02, 2014 10:20 pm
Someone (Gus I think) had a post with pictures of the various shafts side by side.
Post Posted: Sat May 03, 2014 8:16 am
ok... where I spent hours last night looking at CV stuff here and on US forums.....
Users browsing this forum: Google [Bot] and 262 guests
