Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
Posted: Sat Apr 18, 2009 10:04 pm
hey all
the problem
I have a coily rear diff center with a airlocker, its going into a narrow track.The problem is the the flange on the coily diff is the same as wt different pattern to narrow track.
The question
Will a wt diff end of a tail shaft mate to the upper end of a narrow track transfer end???
If so anyone in se melb want to part with a wt rear tailshaft?
The other opion is fitting a wt diff flange to the nt shaft, do these fit?Is it the same uni joint between the two?
cheers andrew
Users browsing this forum: Google [Bot] and 87 guests
