It is currently Tue Oct 20, 2026 10:06 am
Post Posted: Fri Apr 24, 2009 12:21 am
was just bleeding the brakes wen i noticed fluid dripping from the bottom of one of my rear drum brakes. took the wheel off and all other bolts and screws off but the brake still wont come off. please help
lesspostingmorewheeling
Post Posted: Fri Apr 24, 2009 12:34 am
spray some wd40 around the centre hole in the brake drum then hit it with the biggest hammer you can find
Post Posted: Fri Apr 24, 2009 12:41 am
another way is to spray it with wd40 and hit it with a rubber hammer around the edges until it gains a bit of play in it. once you have this play smack the centre in a rotational pattern and eventually it will fall off. nothing will be damaged by a rubber hammer
Post Posted: Fri Apr 24, 2009 1:10 am
slide hammer.
Post Posted: Fri Apr 24, 2009 1:18 am
sweet
thanks heaps
i got it off
but the shoe is shreaded
no were i can get a new on
supercheap stock them?
Post Posted: Fri Apr 24, 2009 1:19 am
yeah supercheap should have them, i got mine from repco
Post Posted: Fri Apr 24, 2009 1:21 am
i've never seen them at supercheap
try repco but take your old ones in so they can match them for you
take a pair of your with you cause there are a few types
I always leave the wheel bolted to the drum to pull em off
Post Posted: Fri Apr 24, 2009 3:58 am
ok
i will get some tomorrow
thanx heaps for all ur help
Vehicle: Grand Vitara
Post Posted: Fri Apr 24, 2009 11:39 am
Mike wrote:
spray some wd40 around then hit it with the biggest hammer you can find
That's pretty much my approach to fixing anything I have to say.
Cheers,
P
[url=http://sunshinecoastdaily.blogspot.com/] Suns
Post Posted: Fri Apr 24, 2009 8:16 pm
I use the wheel bolted on with two or three nuts threaded on a little bit. Sort of like a slide hammer
