It is currently Tue Oct 20, 2026 2:58 pm
Post Posted: Mon May 04, 2009 6:47 pm
well i scored an 84, 1ltr sierra for $500. (sweet)
the standard springs are nice and bendy. and the little motor revs its nipples off (also sweet)
i wanna just put in my 2" shackles, and want to know what shocks will fit? something cheap from u-pull-it.
i know people use commie shocks, but don't know what commie, and under what circumstances.
any info would be appreciated. and im pretty positive someone here will have the answer :-)
Post Posted: Mon May 04, 2009 8:51 pm
Standard shocks will work with extended shackles.
I wouldn't try fitting longer shocks unless you space your bumpstops down at least 25mm or your new shocks will be bumpstop at full compression.
I run VS Commonwhore wagon rear shocks in the front and hiace van rear shocks in the rear, all with 25mm bumpstop extensions.
Jas.
Post Posted: Mon May 04, 2009 9:00 pm
i have sagged 3" springs with 1" lift shackles and 25mm extended bumpstops
with vs wagon rear shockies on the front of my sierra, works well.
on the back i have 4" springs with standard shackles and rancho shockies
and it is horrible until i hook up my trailer, then it is good.
jas are the hiace shockes of a particular model?
Post Posted: Mon May 04, 2009 9:21 pm
last time i ran standard shocks with my longer shackles i snapped a rear spring the first time it flexed..
Users browsing this forum: No registered users and 227 guests
