It is currently Sun Oct 25, 2026 1:13 pm
Vehicle: 2005 Suzuki Jimny JLX
Post Posted: Tue Dec 30, 2014 3:56 pm
Hi,
My rear diff accidentally got drowned so I put brand new bearings and seals in. Now, when the car reaches around 80km/h there is like a howling noise. When I step on the accelerator it slightly disappears. When I let off the accelerator it is conpletely gone. Anyone have any suggestions on what it could be and what I can do? I dont want to be pulling the diff out again.
Thanks
Nick
Post Posted: Wed Dec 31, 2014 12:55 pm
I only know what I've read on here about diff setup. There are tolerances that need to be correct, was yours setup correctly?
Like I said, I'm no expert and maybe it was set up correctly and you know a lot more about diffs than I realise but I had to ask.
Post Posted: Wed Dec 31, 2014 12:56 pm
Whatever the case, I think you'll need to pluck it back out to fix it.
Post Posted: Wed Dec 31, 2014 1:11 pm
I put the bearings and seal in and I had another guy (who is a diff specialist) set the preload and gear meshing. I'll try tighten the pinion nut a little and see what happens
Post Posted: Thu Jan 01, 2015 9:04 am
Don't mess around with it, take it back to the "diff specialist" - I'm no expert, but, based on your description of the problem I would say there's too much clearance and it's not the pinion preload that needs to be adjusted - there's also a high probability the gears are either not meshed where they originally were or are damaged (and possibly both).
Post Posted: Thu Jan 01, 2015 12:26 pm
Get the guy to look at it again, or hunt down a whole replacement 3rd member etc.
If the setup is correct and its still noisey, its likely rooted gears
A muddy paste can be enough to destroy the gears.
Users browsing this forum: No registered users and 431 guests
