It is currently Sun Oct 25, 2026 12:32 am
Vehicle: 06 Jimny VVT
Post Posted: Fri Jan 23, 2015 8:42 am
Hi guys
Last night coming home, I did a drop clutch at the lights :roll: :roll: :roll: .
Once this happened I lost all drive.
I rolled it off the road, thought diff at first, but put in to 4wd and still no drive.
Towed it home. Turned the tail shaft out of the box and it turns the back wheels so transfer ok.
Clutch is moving but I can put it in to any gear without the clutch in even reverse.
Do you think the clutch is stuff or the G box.
Hoping clutch, going to pull the box out tonight, but hoping for some ideas.
If G/Box, has anyone got a second hand VVT box in Sydney area that isn't $1400 as quoted by a wrecker.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jan 23, 2015 8:57 am
clutch cable or another component could be jamed holding the clutch open, preventing the springs from returning it to closed.
Post Posted: Fri Jan 23, 2015 9:56 am
Clutch bearing is pushing the clutch springs and returning to normal position once released
Post Posted: Fri Jan 23, 2015 10:16 am
Snapped mainshaft is pretty common in with those gearboxes. Results in no drive and requires a replacement gearbox.
Post Posted: Fri Jan 23, 2015 11:02 am
That's what im thinking is the issue
Bloody weak boxes :)
Post Posted: Fri Jan 23, 2015 11:04 am
Hope it is something simple.
Post Posted: Fri Jan 23, 2015 11:50 am
Yeah, I am praying the clutch is rooted, Will be a lot cheaper :)
Post Posted: Sun Jan 25, 2015 4:47 am
Ok, Got the box out, It turns out i have snapped the output shaft. the tails shaft has the remains of the rear shaft in it. It is a clean snap. Hopefully i can just change the output shaft to get her running again,
I will update
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Jan 25, 2015 3:55 pm
You should look for play in the transfer case as well. If there was enough force to snap that shaft there is a good chance you have stretched the transfer case chain.
Post Posted: Sun Jan 25, 2015 4:42 pm
That's the mainshaft. ;)
It will be cheaper and easier to fit a second hand gearbox. There's probably 20 components attached to the mainshaft inside the gearbox. Suzuki will want an arm and a leg for a new one too.
Just out of interest, could you please measure the diameter of the shaft near where it broke?
Post Posted: Tue Jan 27, 2015 9:48 am
Got the gear box to work today. Took 5 minutes to get the output shaft out. It isn't part of the gear set. It is a small shaft that sits in the back of the housing. It is only $160 plus GST, problem is it is 2 weeks away. Still not an expensive repair. Giving the workshop Forman a set of Max Tracks to do it. Saves me worrying about it. :)
Everything else looks ok.
Once fixed I am selling it.. Over the 4wding thing, get the Mrs a Swift me thinks :)
Anyone want a 06 Jimny with 2 inch lift, ARB bull bar, Lights, Bluetooth and Sierra Steel rims painted black. Needs windscreen, but overall great car. Wanting $8000 once fixed. NSW :)
Post Posted: Tue Jan 27, 2015 3:44 pm
I'll eat my hat then. :oops:
Post Posted: Tue Jan 27, 2015 4:00 pm
Lol Don't worry, the forman said the same thing until he opened the rear housing on the box. He has never seen this type of setup before 8O
Users browsing this forum: No registered users and 161 guests
