It is currently Sun Oct 18, 2026 12:43 pm
Vehicle: hkbjk
Post Posted: Thu Feb 12, 2015 8:25 am
Are there any easy to see tell tail signs to differentiate between WT and NT sierra transfer case? I bought one as a WT to transfer into the Jimny but just wanted to double check exactly what I have I was told there are 5 different types of transfer case?
Post Posted: Thu Feb 12, 2015 8:37 am
WT won't have a handbrake assembly on the rear output, NT will, but is removable (need a rear output flange from a WT to do it though). Flange bolt pattern is different WT to NT too, Everything else about the cases are identical.
Vehicle: 2000 Jimny
Post Posted: Thu Feb 12, 2015 11:28 am
i'm keen on a sierra t/case as well for my jimny. what sierra am i looking at, been reading this WT & NT over & over, but what year or what does the car look like if you don't mind sharing ??
Vehicle: Drover pickup turk
Post Posted: Thu Feb 12, 2015 11:55 am
Metal flares usually gives it away, although some people put WT flares on a NT. '89 - '96
I like the tuna here
Vehicle: WT sierra, GU CRD
Post Posted: Thu Feb 12, 2015 11:57 am
I am assuming you want the WT case. Most of the time wide tracks have wide metal flares, as opposed to the narrow track's thin black plastic flares.
Wide track started mid way though 88. Other than that you can spot wider spring spacing (offset slightly off the chassis, as opposed to directly under it) and later model grills.
Edit: beaten.
I love ZD30. :)
Vehicle: 2000 Jimny
Post Posted: Thu Feb 12, 2015 12:31 pm
thanks guys, will be something i keep an eye on gumtree for if someone is wrecking a sierra nearby. so WT (i'm guessing is the 5% approx) of 89-96-ish. thanks.
Vehicle: G16b 83
Post Posted: Thu Feb 12, 2015 5:52 pm
Took me 2 months to find one
Vehicle: 2000 Jimny
Post Posted: Thu Feb 12, 2015 6:34 pm
will be longer than that before i have this engine in i think so time is on my side.
Vehicle: hkbjk
Post Posted: Fri Feb 13, 2015 6:30 am
My transfer case (the sierra one I bought) has a plug with 2 wires coming out of it - does this mean anything in determining what year model it is and what gear sets can be bought for it? I read that there are 3 different WT transfers?
I tried putting a photo up of what I have but its not working for me
Does this link work for anyone? (sorry for the poor quality its off my phone)
https://www.facebook.com/photo.php?fbid ... 207f6ae194
Post Posted: Fri Feb 13, 2015 7:09 am
Where do you keep getting the idea there are all these different variants. There aren't.
1.0 litre non-switch case- no good to you, doesn't accept gears. 1.58/2.55 gearing.
1.0 litre switch case- accepts gears, small flange pattern, drm handbrake. 1.58/2.55 gearing
1.3 NT case- accepts gears, small flange pattern (bigger than 1.0- uses jimny/1.3 Sierra/Vitara unis, drum handbrake, 1.409/2.21 gearing
1.3 WT case- accepts gears, Vitara/jimny flange pattern, no handbrake, 1.409/2.21 gearing.
There are a TINY number of early wide track cases which have the NT flanges but no handbrake.
The only difference from your point of view between ALL leaf 1.3 cases are the flanges and they can be swapped easily and/or you can swap NT yokes onto your jimny driveshafts as the unis are the same.
Post Posted: Fri Feb 13, 2015 7:10 am
Your photo is of a WT case.
Vehicle: hkbjk
Post Posted: Fri Feb 13, 2015 9:35 am
Sweet - thanks Steve
Vehicle: 1985 Holden Drover 1.3litre
Post Posted: Fri Jul 19, 2024 12:49 pm
Hi there, sorry for bringing up an old forum! I have a 1985 holden drover with a 1.3 litre NT transfer case (got the drum handbrake). Just wondering can i install WT transfer case reduction gears like these ones (https://www.zookoffroad.com.au/product- ... case-gears)? Thank you so much! Frank
Post Posted: Fri Jul 19, 2024 8:55 pm
Yes
Users browsing this forum: No registered users and 320 guests
