It is currently Sat Oct 24, 2026 4:22 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Thu Feb 19, 2015 9:44 am
I'm looking into setting up my LJ to flat tow
I would like to use the hitch n go frame as it looks the goods and is plated. Can anyone give me the dimensions for it. I would like to incorporate the hitch points into tow points
Post Posted: Thu Feb 19, 2015 3:17 pm
Any more details on these??? Interesting idea
Post Posted: Thu Feb 19, 2015 4:11 pm
I've seen a few and a few back yard ones
The brake is hooked up via pull cable to the brake pedal lights are loomed in with a plug for ease.
The towed vehicle has to be registered but not sure whether limited rego will suffice
Post Posted: Sun Feb 22, 2015 9:25 am
I know in nsw the tow rig has to be 3.5 times the weight of the towed rig
Post Posted: Sun Feb 22, 2015 9:35 am
Is that braked or unbraked, it seem an awfully excessive ratio for braked to me
Pretty sure QLD is different and goes on the towing capacity as per the manufacturer
Vehicle: Suzuki Sierra
Post Posted: Sun Feb 22, 2015 12:12 pm
3.5:1 TOWING RATIO.
The GVM of the motorhome must be at least 31/2 times the laden mass of the vehicle being towed. Unlike towing a trailer, which does not have steering, this requirement is intended to provide stability. All state traffic authorities require adherence to a towing ratio of 3.5:1. To find out how much weight your motor home can haul safely, you must consider the motor home's tow rating and the rating of the tow bar . Depending on the motor home's capabilities, you could easily tow a small car or four wheel drive.
Post Posted: Sun Feb 22, 2015 12:13 pm
Also it's illegal to fit a hitch & go yourself. It has to be fitted by an accredited person or the compliance plate isn't valid.
Post Posted: Tue Feb 24, 2015 7:15 am
I downloaded the guide from QLD transport. From what I read 3.5 -1 ratio is only for unbraked. Maximum towed weight is as per manufacturers specs. You can fit yourself just need an engineer to sign off. Both vehicles need to be registered ( not sure whether limited rego is ok for the towed vehicle). You can use the car lighting or a trailer light bar as long as it is secured.
I would still like to know the answer to my original question though. The dimension between the eyes for the towed vehicle
Users browsing this forum: No registered users and 153 guests
