It is currently Tue Oct 20, 2026 10:06 am
Post Posted: Wed May 27, 2009 10:58 pm
Are 1.3 NT calipers the same as 1L calipers?
Post Posted: Wed May 27, 2009 11:27 pm
i thought 1ltr's had drum front brakes.
Post Posted: Wed May 27, 2009 11:38 pm
so did i, hutch wanted to get some off me and said they were for a 1L NT? is there later models that maybe have discs?
Post Posted: Thu May 28, 2009 12:04 am
I think all Suzuki 1.0's were drum brake front but Maruti 1.0's came with discs.. Not 100% on that though.
Post Posted: Thu May 28, 2009 12:24 am
1.3 nt and WT calipers are the same and so are the 1.0 Maruti.
If you want to upgrade your brakes then the easiest way is using the LWB Vitara vented discs and calipers. Completely bolt on. Only have to trip the stone guard a bit. Bleeding the caliper is a PITA as you need to do it with the caliper unbolted. 2 person job.
Post Posted: Thu May 28, 2009 12:28 am
later 1 litres had discs, pretty sure all had freewheeling hubs
for anyone with a drum brake 1 litre, all you need to convert to disc is from teh 4 14mm bolts that hold the stub axle on outwards, and the flexible brake hose
you can use the drum hub (bit with wheel studs on it) but its so much cleaner to just swap the lot :)
Post Posted: Thu May 28, 2009 12:56 am
Royce you have any idea if the later 1L calipers would be the same?
Post Posted: Thu May 28, 2009 1:02 am
I reckon all leaf spring calipers are teh same, some maruti ones might contain more coke can than suzuki ones but I doubt it makes a difference
Post Posted: Thu May 28, 2009 1:44 am
yes dey iz!
Post Posted: Thu May 28, 2009 1:51 am
sweet thanks heaps guys
Post Posted: Thu May 28, 2009 2:55 am
ive seen 1 litres with solid hubs
