It is currently Sun Oct 25, 2026 4:17 am
Vehicle: suzuki carry
Post Posted: Fri Jun 19, 2015 7:17 pm
hi, ive got a Holden Scurry/suzui carry with the F10A 4 cylinder motor in it. wanting to know if there is any place in Australia (if possible) that sells the electronic ignition set ups
Thanks heaps.
Post Posted: Fri Jun 19, 2015 8:19 pm
I threw a 1.3 (g13b) distributor on mine, which run electronic ignition. Never got it fully sorted but others have.
Post Posted: Fri Jun 19, 2015 9:50 pm
So do the G13B ones bolt straight in?
Post Posted: Fri Jun 19, 2015 10:11 pm
Did on my f10a, but mine was in a sierra.
Post Posted: Sat Jun 20, 2015 12:38 am
So no reason why it shouldn't fit mine yeh?
Post Posted: Sat Jun 20, 2015 10:22 am
No idea- I have no experience with the carry version of the F10a
Post Posted: Sat Jun 20, 2015 8:18 pm
arent all F10A engines the same?
Post Posted: Sat Jun 20, 2015 8:22 pm
Maybe- pretty sure I've seen an f10a with the distributor facing the opposite way to the sierra version.
Post Posted: Mon Jun 22, 2015 12:04 am
I'm assuming it currently has points, as otherwise you wouldn't be asking about a kit.
I just fitted a kit at Piranha Off Road to a 1.0litre points distributor, easy, bolt in kit, costs $320.
I work there - not saying buy our kit, but we do sell one to suit.
An alternative, is that the F10A Maruti versions in the 1990s ran an electronic ignition distributor - might be able to either fit those bits into your body (if the body is mounted differently in a van) or just fit the whole thing + module.
Cheers, Michael V.
Post Posted: Mon Jun 22, 2015 12:40 am
yeh mine is points set up
https://www.google.com.au/search?q=suzu ... B557%3B538
Post Posted: Mon Jun 22, 2015 1:34 am
No.
I believe the block & head are identical, but, the remainder may differ significantly depending on the vehicle. A Sierra (or Maruti) will have the engine mounted, more or less, vertically, but the Carry vans have it tilted at a significant angle, under the front seat.
Oil pans are different, intake & exhaust manifolding is different, as Steve has pointed out, the distributors are mounted differently - who knows what else is different.
Users browsing this forum: Google [Bot] and 122 guests
