It is currently Sat Oct 24, 2026 2:40 pm
Vehicle: 1990 SJ413 with G16B
Post Posted: Sat Jun 27, 2015 7:49 pm
Hey Zookers,
I bought my first Zook a couple of months ago
I took it onto the beach the other day for the first time and when I put it in 4x4 it vibrates a heap. Enough to make the temp + fuel gauge shake like crazy and the 4x4 stick to.
This normal?
SZ
Post Posted: Sat Jun 27, 2015 10:02 pm
Not normal.
Check your uni joints on the front drive shaft.
Vehicle: Drover pickup turk
Post Posted: Sat Jun 27, 2015 10:50 pm
Also worth checking the front driveshaft slip joint too, Hubs locked in mine and I can't go over 60 it's that bad.
I like the tuna here
Post Posted: Sun Jun 28, 2015 9:47 am
Is it lifted?
Post Posted: Sun Jun 28, 2015 7:06 pm
All good!
Checked the drive shaft and the rear one was out 180' on the splines
Still vibrates a bit but no where near as bad as it was. Front uni joint look a bit dodge as well
Cheers fella's
SZ
Yeah it has a 2 inch lift
Post Posted: Sun Jun 28, 2015 7:23 pm
Is the front driveshaft in phase?
Vehicle: Suzuki Sierra Trayback
Post Posted: Sun Jun 28, 2015 10:22 pm
They have align dots punched on slip shaft. Mine had wear in the splines, no vibration just awful rattle. Wide Track and Narrow track have different shaft flange bolt spacings and bolt size. Better to have the same brand Uni joints on the shaft.
Post Posted: Sat Jul 04, 2015 11:57 am
Yeah its in phase
I will check the align dots
Found a set of uni joints on ebay jap made so going to replace those and see how that goes
Thanks again lads
Post Posted: Sat Jul 04, 2015 1:36 pm
Bruce had vibrations in his due to a changed pinion angle. Front uni on the front shaft was running flat while the rear had quite an angle to it
Post Posted: Sun Jul 05, 2015 8:30 am
Cheers mate will have a look at that
Users browsing this forum: Google [Bot] and 91 guests
