It is currently Thu Oct 22, 2026 4:15 pm
Vehicle: Suzuki Vitara 1992
Post Posted: Wed Aug 05, 2015 2:27 am
Hi guys, Seems when i put my foot on the accelerator about half way down the car dies in revs but then picks back up (also does it when i just put it to flat foot from a start) making it kinda hard to take off fast. Anyone had this issue before? or anyone know wat it may be?
Post Posted: Wed Aug 05, 2015 8:27 pm
Seems like it has a flat spot, it really struggles to go up his starts to blow smoke then will stall.
Vehicle: 1991 vitara soft top jlx
Post Posted: Thu Aug 06, 2015 12:35 am
Accelerator pump? Fuel system inc filters etc, spark plug leads, air filter, tho sounds like a fuel issue
Post Posted: Thu Aug 06, 2015 6:35 am
Do you have a picture of the "Accelerator pump" ?(g16a One) going to check the spark plugs and leads today, may also check the fuel filter.
Seems as though its got worse over the course of 2-3 weeks.
Post Posted: Thu Aug 06, 2015 5:21 pm
I'm pretty sure the accelerator pump is inside the carb.
Post Posted: Thu Aug 06, 2015 10:10 pm
When going up hills, i seem to hear something sounds like air going woow, woow, woow, (while climbing in revs), then goes away in high revs
Ill try get a video.
Also seems to blow smoke when really struggling seems to only do it every now and again then goes back to normal.
Vehicle: 91 Vitara SWB Soft Top
Post Posted: Fri Aug 07, 2015 11:05 am
has someone modified the vacuum secondaries? i made mine come on all the time so i have a flat spot but i'm used to it and it goes much harder. sometimes the secondaries don't fully close and its runs with a rich idle and pumps out black smoke and idles high. in my case its a trade off for lack of power
i'm running mine off manifold vacuum not carb vacuum so it has a vacuum leak too, will make it all mechanical once i can be bothered
Post Posted: Fri Aug 07, 2015 1:22 pm
found the problem i think gotta make a gasket from carby to inle http://m.imgur.com/MPYR2FP
Users browsing this forum: No registered users and 89 guests
