It is currently Thu Oct 22, 2026 8:22 pm
Post Posted: Fri Aug 14, 2015 9:49 am
Hi ya folks, a friend has just bought an auto Jimny, what's the procedure for towing an auto when the engine isn't running?
Post Posted: Fri Aug 14, 2015 10:34 am
Put it in 2wd and pull the rear tailshaft.
Post Posted: Fri Aug 14, 2015 10:40 am
in a prefect world ;)
My bad, I'll reword my question...
If an auto sucks in water during a crossing and stalls what's the procedure for pulling it out?
Post Posted: Fri Aug 14, 2015 11:07 am
Gearbox or Transfer in neutral. Pull it out.
Post Posted: Fri Aug 14, 2015 11:35 am
no neutral in the Jimny transfer so I assume auto trans in neutral? I've never owned an auto so it's all very foreign to me.
I read years ago that you should only flat tow an auto for short distances, is that true?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Aug 14, 2015 11:47 am
gear box in neutral. dont tow it unnecessarily far or fast or both.
Post Posted: Fri Aug 14, 2015 12:00 pm
The concern is that the oil pump in the auto is not working when the car is off. As has been said, drop it in neutral for recoveries and go.
If you're going to be flat towing you need to remove the tailshaft or the bearings will be spinning without oil for an extended period of time.
Post Posted: Fri Aug 14, 2015 12:16 pm
thanks lads
Users browsing this forum: Baz89 and 453 guests
