It is currently Sat Oct 24, 2026 5:52 am
Post Posted: Thu Aug 20, 2015 6:13 am
As above what's the easiest way to get the anti theft bolts off from the bracket that holds the ignition barrel on?
Post Posted: Thu Aug 20, 2015 7:36 am
Hammer and cold chisel
Post Posted: Thu Aug 20, 2015 8:24 am
^^^ That's how I got mine off
Post Posted: Thu Aug 20, 2015 9:26 am
Ya didn't believe the key number is on the door lock?????
bye
Post Posted: Thu Aug 20, 2015 9:40 am
bye
:rofl: Point well taken!
...although I purchased a Maruti ignition switch and door lockset ($80 US from Roadless Gear) because the previous owner seemed to have a problem with the existing switch... he installed a starter button in the tintop, then threw away the keys!
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Vehicle: SWB Vit
Post Posted: Thu Aug 20, 2015 10:23 am
Vice grips
Post Posted: Thu Aug 20, 2015 11:26 am
ozzycouch wrote:
Vice grips
don't work as they are pyramid shape :wink:
Vehicle: SWB Vit
Post Posted: Thu Aug 20, 2015 12:10 pm
You can grab them at the base as the metal is quite soft :wink:
Post Posted: Thu Aug 20, 2015 12:18 pm
not the ones I took out
Post Posted: Thu Aug 20, 2015 5:27 pm
I didn't have a number on the barrel....
Post Posted: Thu Aug 20, 2015 5:55 pm
It's just 4 small digits..I bought a couple of wrecks without keys over the years, and always been able to get keys cut..maybe it's on the drivers side door lock??
bye
Post Posted: Thu Aug 20, 2015 9:41 pm
I have pmed you mate
Post Posted: Fri Aug 21, 2015 6:27 am
Vice grips worked awsome!!!! The top bolt was woeful had to rip the speedo out to get to it...
Post Posted: Fri Aug 21, 2015 7:44 am
THERE'S ALSO A SPECIALIST LOCKSMITH TOOL SHAPED LIKED A SCREWDRIVER WITH A HARDENED BLADE FOR THOSE ANTI THEFT SCREWS FOR NUMBER PLATES..
Vehicle: MG410 Gypsy
Post Posted: Fri Aug 21, 2015 10:23 am
Vic grips worked a treat like nathan said... just a matter of getting it to the top bolt haha
Vehicle: Vitara 1.6
Post Posted: Mon Aug 24, 2015 8:32 am
+1 for the easy out bits.
1. Drill small hole
2. Cuck in the easy out withe the drill in reverse.
Sent from my SM-G900I using Tapatalk
Users browsing this forum: No registered users and 384 guests
