Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
fire60
Joined: Sat Oct 16, 2010 2:02 am Posts: 96 Location: Wellington NZ
 Posted: Sun Dec 06, 2015 9:22 am |
Does any one know what the standard fuel pressure is for a 16V motor?
I have had to fit an after market fuel pump and are having problems, have been told that the fuel pressure may be too high.
Regards, Pete
Gwagensteve
 Posted: Sun Dec 06, 2015 12:00 pm |
The pump doesn't set the pressure, the regulator sets the pressure. If the pump has way more flow than standard, it could be causing excessive pressure in the fuel rail. What's the symptoms?
fire60
 Posted: Sun Dec 06, 2015 12:37 pm |
Thanks for the reply.
That's what I thought. But was told to look at pressure. We are not running original pump. Symptoms are: engine fires up but will only run on 3/4 throttle and above will not idle. This is a reconed engine, first start up and is a replacement for my original 8v carby. I was thinking it may be a sensor issue?
Pete
Gwagensteve
 Posted: Sun Dec 06, 2015 12:42 pm |
Is it super rich?- black smoke, fuel smell etc?
fire60
 Posted: Sun Dec 06, 2015 12:44 pm |
Gwagensteve
 Posted: Sun Dec 06, 2015 2:51 pm |
Then it's unlikely to be excessive pressure. Sure it has adequate pressure? The regulator is set at 41.2psi (290 Kpa)
fire60
 Posted: Sun Dec 06, 2015 6:41 pm |
Thanks Steve, I will check the pressure
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 152 guests
