It is currently Wed Oct 21, 2026 6:30 pm
Post Posted: Wed Feb 03, 2016 11:19 pm
Hey guys.
What method have people used to weld a vit rear center?
I usualy fill the valleys on the gears up to allow some movement still? Is the vit carrier strong enough for this method? Driving with it done this way feels a lot more forgiving.
Any input appreciated
Post Posted: Fri Feb 05, 2016 10:03 am
I welded the gears together and the gears to the cage anywhere possible, 4 axles later and the diff looks fine. Why would it be more forgiving to introduce a shock load every time you turned a different direction? If there is movement the diff is able to travel through that small range quickly and then lock up hard.
Post Posted: Fri Feb 05, 2016 10:48 am
Im with zookfan. The shock loading (read: auto lockers) will be worse then it being solid state. Fill and fill and fill. Then buy a spool
Post Posted: Fri Feb 05, 2016 12:23 pm
I'm with Wilso on this one, a spool is reversable, and they are cheap enough aswell.
Post Posted: Fri Feb 05, 2016 12:29 pm
I heard CAP's were the go?
Post Posted: Fri Feb 05, 2016 1:15 pm
The free movement of the gears with a small amount of play makes the car drive better. We actually experimented with 2 lj diffs. The one not welded solid didn't understeer anywhere near as much amd felt better on tar.
In this case i will weld them solid!
Cheers guys.
Post Posted: Sun Feb 07, 2016 3:09 pm
I really can't see the difference man. Happy to be wrong but it seems a strech
Post Posted: Sun Feb 07, 2016 6:46 pm
Don't go the low range spool if you do I exploded one and a made cracked his and binned it there rubbish
Post Posted: Mon Feb 08, 2016 11:41 am
Lror sell 3 types trailgear/yukon/trail tough.
People have broken both but not the yukon thus far. My spools will pop one day due to being trailgear
Vehicle: Vitara 1994
Post Posted: Thu Feb 18, 2016 2:16 am
Cheers guys.
Interesting
Post Posted: Thu Feb 18, 2016 4:32 pm
True that! How can ~5-10mm "movement" between the star gears make any noticeable difference in how it drives? That gear movement would probs correspond to like a few centimeters of tire rollout...
Post Posted: Thu Feb 18, 2016 6:13 pm
Quite the opposite.
A few ' will work out to be 200mm on a 31.
So when turning, rather than a constant drag, it will load and unload.
And no i haven't broken anything due to this
Post Posted: Thu Feb 18, 2016 6:45 pm
1 degree movement at the star gear is actually 6.87mm of circumference for a 31" tyre. You'd have to have almost 30 degrees free to get 200mm. And 200mm is only 8% of the tyre circumference.
Turning radius of a Sierra - 5.09m
Axle width for a WT - 1.34m (front)
So the inside wheel through a 90 degree turn is travelling (2(Pi)*(5.09-(1.34/2))*90)/360=6.94m
Outside wheel through a 90 degree turn is (2(Pi)*(5.09+(1.34/2))*90)/360=9.04m
The outside wheel is over speeding the inside by a rate of 30%, the car wouldn't be moving with an unloaded diff for more than roughly 175mm. Obviously this is all at full lock and that number grows basically exponentially the closer the wheels are to straight but I just can't realistically see this being an advantage.
When turning in one direction it will only be unloaded for the very short time that you are changing direction, there's no way it can unload while the tyres are still trying to turn at different speeds.
Post Posted: Fri Feb 19, 2016 4:00 am
Zook_Fan unless no one has told you today, you is a nerd.
Post Posted: Fri Feb 19, 2016 9:59 am
:lol: no you got in first today
Post Posted: Sun Feb 21, 2016 8:34 am
So much math lol..
I'm juat going to say it works as we actually tested it.
Id say you get morr 5-10'? Irrelevant really
Users browsing this forum: Google [Bot] and 295 guests
