| Author |
Message |
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Wed Feb 03, 2016 11:19 pm |
Hey guys. What method have people used to weld a vit rear center? I usualy fill the valleys on the gears up to allow some movement still? Is the vit carrier strong enough for this method? Driving with it done this way feels a lot more forgiving.
Any input appreciated
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Fri Feb 05, 2016 10:03 am |
I welded the gears together and the gears to the cage anywhere possible, 4 axles later and the diff looks fine. Why would it be more forgiving to introduce a shock load every time you turned a different direction? If there is movement the diff is able to travel through that small range quickly and then lock up hard.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri Feb 05, 2016 10:48 am |
Im with zookfan. The shock loading (read: auto lockers) will be worse then it being solid state. Fill and fill and fill. Then buy a spool
greenzook89
Joined: Sun Sep 06, 2009 11:30 pm Posts: 2591 Location: Ipswich
 Posted: Fri Feb 05, 2016 12:23 pm |
31zook wrote: Im with zookfan. The shock loading (read: auto lockers) will be worse then it being solid state. Fill and fill and fill. Then buy a spool I'm with Wilso on this one, a spool is reversable, and they are cheap enough aswell.
_________________ 31zook wrote: Makes me want something similar
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Feb 05, 2016 12:29 pm |
I heard CAP's were the go?
jonno_racing
 Posted: Fri Feb 05, 2016 1:15 pm |
The free movement of the gears with a small amount of play makes the car drive better. We actually experimented with 2 lj diffs. The one not welded solid didn't understeer anywhere near as much amd felt better on tar.
In this case i will weld them solid! Cheers guys.
31zook
 Posted: Sun Feb 07, 2016 3:09 pm |
I really can't see the difference man. Happy to be wrong but it seems a strech
suzukikid
Joined: Sun Jan 14, 2007 10:30 pm Posts: 2803 Location: Melton Victoria!
 Posted: Sun Feb 07, 2016 6:46 pm |
Don't go the low range spool if you do I exploded one and a made cracked his and binned it there rubbish
31zook
 Posted: Mon Feb 08, 2016 11:41 am |
Lror sell 3 types trailgear/yukon/trail tough.
People have broken both but not the yukon thus far. My spools will pop one day due to being trailgear
vet 180
Vehicle: Vitara 1994
 Posted: Thu Feb 18, 2016 2:16 am |
jonno_racing wrote: The free movement of the gears with a small amount of play makes the car drive better. We actually experimented with 2 lj diffs. The one not welded solid didn't understeer anywhere near as much amd felt better on tar.
Cheers guys. Interesting
JrZook
 Posted: Thu Feb 18, 2016 4:32 pm |
31zook wrote: I really can't see the difference man. Happy to be wrong but it seems a strech True that! How can ~5-10mm "movement" between the star gears make any noticeable difference in how it drives? That gear movement would probs correspond to like a few centimeters of tire rollout...
jonno_racing
 Posted: Thu Feb 18, 2016 6:13 pm |
JrZook wrote: 31zook wrote: I really can't see the difference man. Happy to be wrong but it seems a strech True that! How can ~5-10mm "movement" between the star gears make any noticeable difference in how it drives? That gear movement would probs correspond to like a few centimeters of tire rollout... Quite the opposite. A few ' will work out to be 200mm on a 31. So when turning, rather than a constant drag, it will load and unload. And no i haven't broken anything due to this
Zook_Fan
 Posted: Thu Feb 18, 2016 6:45 pm |
1 degree movement at the star gear is actually 6.87mm of circumference for a 31" tyre. You'd have to have almost 30 degrees free to get 200mm. And 200mm is only 8% of the tyre circumference.
Turning radius of a Sierra - 5.09m Axle width for a WT - 1.34m (front)
So the inside wheel through a 90 degree turn is travelling (2(Pi)*(5.09-(1.34/2))*90)/360=6.94m Outside wheel through a 90 degree turn is (2(Pi)*(5.09+(1.34/2))*90)/360=9.04m
The outside wheel is over speeding the inside by a rate of 30%, the car wouldn't be moving with an unloaded diff for more than roughly 175mm. Obviously this is all at full lock and that number grows basically exponentially the closer the wheels are to straight but I just can't realistically see this being an advantage.
When turning in one direction it will only be unloaded for the very short time that you are changing direction, there's no way it can unload while the tyres are still trying to turn at different speeds.
31zook
 Posted: Fri Feb 19, 2016 4:00 am |
Zook_Fan unless no one has told you today, you is a nerd.
Zook_Fan
 Posted: Fri Feb 19, 2016 9:59 am |
 no you got in first today
jonno_racing
 Posted: Sun Feb 21, 2016 8:34 am |
So much math lol.. I'm juat going to say it works as we actually tested it. Id say you get morr 5-10'? Irrelevant really
