It is currently Wed Oct 21, 2026 1:28 pm
Post Posted: Sat Feb 20, 2016 5:39 am
Pulled down a gearbox that had lost drive in all gears bar 1st and reverse. It has broken the main shaft. Is this a common thing with these gearboxes? If I look for another busted gearbox to rob parts from am I going to find the same thing?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Feb 20, 2016 7:13 am
first time I've heard of a problem with them.
Post Posted: Mon Feb 22, 2016 7:43 pm
So no one knows anything? I've heard they were weak but can't determine the actual issue
Post Posted: Mon Feb 22, 2016 8:45 pm
My sister in laws Jimny is in the shop with the exact same problem. 08 vvt Jim. Sorry Scrawny I dont have anymore info as its in Townsville
Post Posted: Mon Feb 22, 2016 9:11 pm
Did you use 4wd on road?
Post Posted: Tue Feb 23, 2016 7:20 am
Not mine Shep but the owner was an experienced 4wder. When it happened he was on the highway in 2wd with minimal strain on anything
Vehicle: zook
Post Posted: Tue Feb 23, 2016 8:23 am
Probably not but using parts from a busted gearbox I would not recommend. Chunks of metal floating about a gearbox would likely have damaged other bits. I would look for a good replacement box.
Users browsing this forum: Google [Bot] and 138 guests
