It is currently Wed Oct 21, 2026 1:28 pm
Vehicle: Suzuki Sierra 1.3JX
Post Posted: Thu Mar 03, 2016 6:17 pm
Gday guys
I have a few questions i have just brought a 1991 suzuki sierra 1.3 jx soft top with a g13ba engine and a 5speed maunal.
Once the revs gets to 3k there is an extremely loud tinny noise the seams to come frome the engine but i cant quite find out exactly where.
The car has had a previous major service on the 9/10/15 and has only done 3k since includiing
Oil filter z172
10w40 semi syn oil
Gasket valve cover
Timing belt kit
Diff oil 80w90
Gear oil 75w85
Gasket oil pan
Water temp sensor
Key wat crank
Dot 3 break fluid
Front main oil seal
Cam shaft pully
Timing pully
There was quiet a lot of vavle noise so i have reset the valve clearences when hot to .25 on the inlet and .28 on the exhaust. Changed the oil, oil filter and used a valve additive yet the noise is still there. I have also removed the exhaust heat shield thinking that might be rattling and have checked the cat sheild.
Any ideas would be greatly appreciated
Post Posted: Thu Mar 03, 2016 6:42 pm
Noises are impossible to diagnose on a forum.
Get ready for a list of everything ever.
Sorry. Even posting a video is often unhelpful as the sound isn't directional or good enough.
Post Posted: Thu Mar 03, 2016 6:56 pm
I was thinking as much but was in the hope that someone had encountered a similar issue and could point me in the right direction of a few things to look at
Post Posted: Thu Mar 03, 2016 7:36 pm
I understand, but it's just too hard.
Vehicle: suzuki sierra sj51t
Post Posted: Tue Mar 08, 2016 5:39 pm
Hi Fellas.
This is the first time I have ever replied to anything on this site.
But, just wondering. You said you reset your rocker clearances to .25 and .28 is that inches your are using? If so, .25 means 250 thou. which is one quarter of an inch.
I reckon they should be .006 and .008
Regards, Wayne.
Vehicle: Drover pickup turk
Post Posted: Tue Mar 08, 2016 6:18 pm
I like the tuna here
Post Posted: Wed Mar 09, 2016 4:42 am
Hi Fellas.
Please disregard my last post. Clearly you are talking mm. I apologise for insulting everyones intelligence.
I think I must have been in the sun too long yesterday.
Regards, Wayne. :oops:
Vehicle: SJ80, SE416
Post Posted: Wed Mar 09, 2016 5:58 am
Being a G13ba in a '91, I wonder if it's been swapped from a later model Sierra and it's got a cracked piston skirt?
Post Posted: Wed Mar 09, 2016 6:50 am
g13ba started before 91
Users browsing this forum: Google [Bot] and 137 guests
