I have removed one, one the odd chance someone may want to buy one, but I will be the last I remove, as from memory it was a pain in the arse, did come out somehow though. good luck
Joined: Sun May 03, 2009 11:30 pm Posts: 646 Location: Melbourne
Posted: Mon Aug 29, 2016 9:00 pm
It feels like its just sitting in there....no clips or screws. The only thing that seems to be stopping me from lifting it out is that bracket in the middle!
Posted: Fri Sep 02, 2016 12:41 am
B4T - no nuts from underneath, it's threaded into the body....looks like it was made that way so you can't just simply remove that brace.
Got bar work - that did cross my mind but too much effort.
The reason I wanted to remove it in the first place is because I managed to get water in there. I ended up just drilling a small hole from underneath the car to drain the water out and then just inserted a rubber plug afterwards.
Users browsing this forum: Google [Bot] and 64 guests
