It is currently Fri Oct 23, 2026 11:16 pm
Post Posted: Wed Oct 12, 2016 9:32 am
Hey guys does any one do a reduced loom for a coil pack baleno conversion?
im doing one for a mate atm and its doing my head in, the wiring that came with it is a mess, i reduced the loom and i cant figure it out,
when power is hooked up, the ecu turns on, the fuel pump turns no solid (no timer off) and the injectors run at 100%... i have double checked the wring and everything appears to be right accordig to Pjzooks instructions.
we now have another loom/ecu that we got cheap but im not overly keen to hack into it and remove the million plugs
any ideas?
Post Posted: Wed Oct 12, 2016 10:29 am
Check the relays
The G (ecu trigger earth from relay)
The Y/Bl (ecu trigger earth from relay).
Check and the R/B, and W wires, also see if they have been joined somewhere
Check the few earths
Has the engine loom been molested?
Or
Start from scratch
Keep the entire baleno engine loom (the ecu plug, and blug plue).
I use the alt and starter wires etc too, no cutting and joining of any wires, so it's all plug and play, and easily replaced off the shelf.
I changed the loom taping/covering slightly, to adjust the position of the air temp sensor, so i can use a fancy intake pipe from megazip.
I strip out all the excess crap from the sierra loom.
Auto looms are a lot more work to clean up, I have a manual loom and auto.
I kept my auto loom plug and play, so I can try the baleno auto controller on the vit transmission.
As long as the earths are connected and B/R and B/Y are bridged it will start and run without any other mods, auto controller connected or not.
The other ecu plug and blue plug (dash side) are the only two plugs you need to change/modify
I relocated the diag terminals and put them under the dash too.
The rest is simple, as there's only a handful of wires to join to the sierra loom, and only a handful of wires to connect to relocate a lot of baleno stuff.
Just carefully strip and label, you shouldn't even need a diagram.
Post Posted: Wed Oct 12, 2016 10:33 am
Ok so i have been over the current wiring 3x now
as soon as you hook up power to the IGN circut on the ecu, it turns on the efi relay and the fuel pump relay,
and thats it, it dosent purge and switch off, just holds the fuel pump on
it also holds the injectors full open.
is this a falt with the ecu? im fairly not keen to hook up the new ecu as i dont wish to fry it if thats the problem
Post Posted: Wed Oct 12, 2016 10:39 am
jdk81 wrote:
Start from scratch
The new loom/ecu is manual so it shouldnt be 2 hard. i will start a fresh.
the whole old loom was butcherd so i wired it with new standard relays, the same way i have done gti's etc in the past.
Post Posted: Wed Oct 12, 2016 11:42 am
Post Posted: Wed Oct 12, 2016 11:45 am
If u take a pic of the ecu i can do you one like this with fuel pump wire earth and ignition to connect
Post Posted: Wed Oct 12, 2016 11:56 am
Thats a good looking loom
what do you charge to do that?
Post Posted: Wed Oct 12, 2016 12:42 pm
Normally $350 if u supply tape and black flexy conduit but i only do it for the main type of baleno ecu, there are 3 different ones.
Even with a template it still takes a good 3-4hrs. Can do for less if the loom comes stripped of all tape and coverings.
Vehicle: 98 sierra coily
Post Posted: Wed Oct 12, 2016 6:00 pm
You don't have the y/b start wire hooked up to ign do you? I know That keeps the pump running.
Post Posted: Wed Oct 12, 2016 6:02 pm
Just got my loom looking like that. Felt good after many hours fiddling and fault finding.
Post Posted: Wed Oct 12, 2016 9:32 pm
Nope not needed
Post Posted: Wed Oct 12, 2016 9:35 pm
Done over 10 looms last year or two no issues.
No vss, 8.5/9 ltrs per 100km on the hwy.
100,000km + in my present zook and the same in the last.
Post Posted: Thu Oct 13, 2016 10:09 am
Yeah id happily pay you to do my one If i go efi in the ute.
so the new loom we got is one with the coil packs on the back of the head not the rocker covers ones.
can i just swap the plugs? as in solder the rocker cover coil plugs onto the loom for the rear ones?
Post Posted: Thu Oct 13, 2016 11:20 am
Ooo not sure ive hardly seen them in wa.
If the ecu isnt same as mine then my loom be no good to u as pinouts would be different. If ecu is the same be safe to assume u can just lengthen the wires
Post Posted: Thu Oct 13, 2016 12:41 pm
The coils on the back of the head are 4pin plugs. I'm not sure what the difference is with the extra wires.
There's not much to join from the engine harness side to the ecu, sounds like something is mixed up in the fuse/power/ecu side
From memory I have had my starter wire connected to the ecu, and not connected, Didn't make a difference.
Post Posted: Thu Oct 13, 2016 2:36 pm
Currently at work but im 99% sure they were 3 pin jiggas..
I will let you guys know in the morning!
There a completely different, much larger plug.
Vehicle: 2020 Vitara Turbo
Post Posted: Thu Oct 13, 2016 8:45 pm
This is the same one as I currently have for my ute. After a bit of cross referencing etc, it seems most of the wires/pinouts are the same colour. I'm about to start doing my loom after I finish Jayses 16b + auto conversion hopefully tomorrow night.
Post Posted: Fri Oct 14, 2016 7:19 am
is the ign feed/start wires the same!
Post Posted: Fri Oct 14, 2016 7:26 am
Haven't checked that far, I just went through and made sure the coilpack side was close and the injector feeds were close. Usually I don't use the donor loom side of the start wires anyway, I use the sierra side as it's all there and already connected to the barrell.
Post Posted: Fri Oct 14, 2016 8:19 am
Yeah i just hook the baleno ignition wire to the white and black (from memory) sierra ignition, retaining the baleno fuse box isnt ideal but its already got all the fuel pump feeds and powers straight from there, i just tuck it up behind the glovebox and mount the ecu to the top inside the glovebox with a cutout for the plugs
Post Posted: Fri Oct 14, 2016 8:35 am
Yep thats today's job!
Hopefully we will be driving after lunch
Post Posted: Fri Oct 14, 2016 8:52 am
Just make sure u got the black and orange earth on the engine loom connected for the injector earth. Normally pops out where the clutch cable comes out the firewall, i just take out one of the 10mm bolts holding the cable on and connect to that otherwise no injector pulse
Post Posted: Fri Oct 14, 2016 8:53 am
There is also a redundant plug with yellow on it in that same area, dont stress if its not connected
Post Posted: Fri Oct 14, 2016 4:28 pm
Legends. it starts and runs!
i still need to clean up the wiring loom as i have the whole baleno loom on the passengers side seat/floor.
i had to run a new Power feed from the battery to the fuse box, so i used an old chinese winch earth wire, fitted in nice.
the models with the 2x coil packs behind the head have the same wire colors etc, just extended and added the right plugs for the one on's on the rocker cover.
now back to it. few more hours and it can go back to its owner! thanks for the help lads
Post Posted: Fri Oct 14, 2016 6:28 pm
Awesome man, thanks for the info on the wiring too, I'm actually going to mount the coils on the firewall away from the engine, just to get away from the heat. After owning Nissan imports I know the hassles that come with coils cracking and earthing.
Post Posted: Fri Oct 14, 2016 11:18 pm
More likely you didn't notice the difference.
The start signal not being connected to the ECU will not prevent the engine from starting or running, if connected it will however make the engine easier to start in cold weather (retards the timing & enriches the mixture whilst cranking) and the most noticeable difference is that it is one of two signals that activates an "unflood" mechanism - if the ECU senses WOT (wide open throttle) and crank simultaneously it kills injection - this allows you to hold the throttle open and crank the engine to clear excess fuel if the engine will not start because it has been flooded.
